My photon always disconnects every few seconds
Hello,
I have a problem with my photon. My device always disconnects every few seconds and connects again to cloud.
The device is connected to a powersupply. In this case somtimes I’m not able to flash the firmware OTA.
If I connect the device to my laptop on a usb port my photon stays connected to the cloud.
Is this a bug or is the power supply bad. Can you help me please? Thanks.
Kin of regards
Place your device in safe mode and see if that still happens
Hi @Serkan,
If it works when connected to a different power supply, I would think your original power supply is bad?
David
@kennethlimcp I treid now the safemode. In safe mode the device stays connceted.
@Dave I reset device after the safe mode and the device stays a long time for hours connected to the cloud. It seems that the powersupply is ok. I think it’s a sporadically. Is there someting to pay attention in the code.
Thanks, Serkan
Hi @Serkan,
Cool! So yes checking your code would be good. Look for anything that blocks (like a hard delay) for long periods of time. If you block more than 10-30 seconds, your device may disconnect from the cloud. The newer multi-threading support on the Photon should reduce this problem considerably however.
David
