Monitor One Mobile Weather Tracker
Hi everyone, here's my latest project using the new Monitor One that uses a BME680 to get weather data and publish it to the Cloud between sleep cycles.
Nice project!
Nice project! Just received my Monitor One and I'm looking for a Temperature Sensor. Since the environment click is inside the box do you think you will get good temperature/humidity reading?
Thanks! Temperature should be pretty accurate, albeit with some lag. Humidity might be higher within the enclosure than outside, but I haven't checked that yet.
My opinion is that the temperature will be spot on, or very very close because the device is sleeping, wakes up, then reads the temperature.
Now on the humidity front, I'm unsure how the enclose isolation will play out.
Cheers
