I found this library.
https://github.com/peninquen/Modbus-Energy-Monitor-Arduino
I think it would be of great benefit to be port for Particle.
The library supports several types of energy meters: Eastron SDM120, SDM220, SDM530 and SDM630.
I do not know how specific to a AVR platform, I hope that can be easily adjusted to STM (Particle).
@peekay123
I tried to compile the example.
Problem occurs only with declaration of serial port.
As I can see, there is nothing specific on the AVR platform.
It probably will not be very difficult to make a declaration of the hardware serial port on Electron / Photon/Core.
I managed to ported library Web IDE to compile without problem.
But I have a problem that I do not know how to solve.
Somewhere in the Arduino libraries has SERIAL_TX_BUFFER_SIZE definition but that definition does not in Particle platform.
I now manually define #define SERIAL_TX_BUFFER_SIZE 256 in the file ModbusSensor.h. But I do not know how to find the appropriate required in Particle serial port (256 I define randomly.)
I would use SERIAL_BUFFER_SIZE. You shouldn’t need to include anything to use it. The TX and RX buffers are the same size.
With Arduino compile without problem with SERIAL_TX_BUFFER_SIZE.
With the change of
// If ((* _hwSerial) .availableForWrite () == SERIAL_TX_BUFFER_SIZE - 1) {// TX buffer empty
// with
if ((* _hwSerial) .availableForWrite () == SERIAL_BUFFER_SIZE - 1) {// TX buffer empty
How did you connect the RS485/Modbus kWh to the Particle?
@developer_bt Care to share? I’ve made the same changes, including the following:
#define MB_SERIAL_PORT &Serial1 // Arduino has only one serial port, Mega has 3 serial ports
However I’m getting all values printed as zeros. Same modbus settings as other (successful) libraries, so I know these are correct.
I’ve also updated my config to match my device:
#define MB_SERIAL_PORT &Serial1 // Arduino has only one serial port, Mega has 3 serial ports.
// if use Serial 0, remember disconect Tx (pin0) when upload sketch, then re-conect
#define MB_BAUDRATE 2400 // b 2400
#define MB_BYTEFORMAT SERIAL_8E1 // Prty n
#define TxEnablePin A1
#define ID_1 1
