Hi all,
I have an SDM120 modbus energy meter. I’m using the modbus library provided by the Particle IDE (Particle Build), which can be found here:
Modbus-Master: GitHub - lithiumhead/ModbusMaster
Some documentation on my device:
http://docs-europe.electrocomponents.com/webdocs/1584/0900766b81584bd7.pdf (high level)
http://www.flanesi.it/blog/download/sdm120c/SDM120-Modbus_protocol_V2.1.pdf?dl=0 (the protocol)
I’m struggling to decode the modbus response into something helpful.
See below the sketch I am using:
#include "ModbusMaster.h"
// instantiate ModbusMaster object as slave ID 1
ModbusMaster node(1);
// initialize Modbus communication baud rate
node.begin(2400);
node.enableTXpin(A1); //A1 is the pin used to control the TX enable pin of RS485 driver
//node.enableDebug(); //Print TX and RX frames out on Serial. Beware, enabling this messes up the timings for RS485 Transactions, causing them to fail.
Serial.println("Starting Modbus Transaction:");
static uint32_t i;
uint8_t j, result;
uint16_t data[10];
i++;
result = node.readInputRegisters(0x0000,2);
Serial.println("");
// do something with data if read is successful
if (result == node.ku8MBSuccess) {
Serial.print("Success, Received data: ");
for (j = 0; j < 2; j++) {
data[j] = node.getResponseBuffer(j);
Serial.print(data[j], HEX);
Serial.print(" ");
Serial.println("");
} else {
Serial.print("Failed, Response Code: ");
Serial.print(result, HEX);
Serial.println("");
delay(5000); //if failed, wait for bit longer, before retrying!
delay(1000);
With the most important section of the codebase being result = node.readInputRegisters(0x0000,n);
with n set to 1:
Success, Received data: 4371 0
with n set to 2:
Success, Received data: 4371 6666
Setting n to anything higher just yields the same result as n=2.
Reading the register 0x0000 yields the Voltage, which should be around 240V (I can confirm this by reading the value on the meter).
I’m aware that a couple of resources already exist, but these are tailored to the SDM, whereas I’m after an implementation that uses the modbus library, as I plan to add other modbus devices. Some resources:
Would appreciate some guidance on reading this properly. This is my first (scary!) venture into Modbus.
