SDM120 Modbus change ID
Hi all,
I have a SDM120 Modbus energy meter where I would like to change the id from 1 to 2. I have already figured out how to read from the energy meter but I had no luck so far writing to it.
The SDM Manual says that
So I assume that writeMultipleRegisters is correct:
writeMultipleRegisters(uint16_t u16WriteAddress,
  uint16_t u16WriteQty)
The write address is 0x0014 and the Write Qty is 2.
But I must be doing something wrong because I always receive in the Particle Console the value 226 which stands for Timeout Error.
So I would be very grateful if you could help me a little bit :slight_smile:
#include "ModbusMaster.h"
// instantiate ModbusMaster object as slave ID 1
ModbusMaster node(1);
	// initialize Modbus communication baud rate
	node.begin(2400);
	node.enableTXpin(D7); //A1 is the pin used to control the TX enable pin of RS485 driver
	//node.enableDebug();  //Print TX and RX frames out on Serial. Beware, enabling this messes up the timings for RS485 Transactions, causing them to fail.
	Serial.println("Starting Modbus Transaction:");
    uint8_t result;
    node.setTransmitBuffer(0, 0x4000);
    node.setTransmitBuffer(1, 0x0000);
    result = node.writeMultipleRegisters(0x0014, 2);
   delay(10000);
