Mobile app for particle photon
hello! i’m new. i’ve start to study and use particle photon at school and i try to create a very simple mobile app. at the beguinning i’ve created a web app or html page to interact with my photon. with this app i can turn on led d0,d7 make a beep or start nyan on d0. the html works fine. i’ve tried to make a simply mobile app with adobe PhoneGap build. i’ve created my github repository with html and find on github a repository with xlm code. i’ve created the app and installed on my android. but when i try to lanch a command it give me an error page. it say webpage not available. impossible to connect: https:api.particle.io/v1…
why: net::ERR_INVALID_RESPONSE.
i copy my code. if someone can help me i’ll really apriciated the help. thank you in advance.
–xml code:
<?xml version="1.0" encoding="UTF-8" ?>
<widget xmlns   = "http://www.w3.org/ns/widgets"
    xmlns:gap   = "http://phonegap.com/ns/1.0"
    id          = "com.yoursite.basicparticle"
    version     = "1.03.06" >
  <name>Photon-WebApp-Onide</name>
  <description>
      Web app creata da onide
  </description>
<gap:plugin name="cordova-plugin-whitelist" source="npm"/>
  <plugin name="cordova-plugin-whitelist" spec="1.3.2" />
  <preference name='phonegap-version' value='cli-8.1.1' />
  <preference name='pgb-builder-version' value='2' />
  <preference name='phonegap-version' value='cli-7.0.1' />
  <preference name="phonegap-version" value="cli-6.5.0" />
  <preference name="orientation" value="default" />
  <preference name="fullscreen" value="true" />
  <preference name="android-installLocation" value="auto" />
</widget>
–html code:
<html lang="en">
<head>
<meta charset="UTF-8"><meta name="viewport" content="width=device-width, initial-scale=1.0"><meta http-equiv="X-UA-Compatible" content="ie=edge">
<title>Progetto Rutilio ITS 2019</title>
</head>
<body>
<form action="https://api.particle.io/v1/devices/***/nyan?access_token=***" method="POST">
<label for="stato"&gt;Stato &lt;/label><input id='stato' type="text" name="arg">
<button type="submit">NYAN!!</button>
</form>
<form action="https://api.particle.io/v1/devices/***/rgbLed?access_token=***" method="POST">
<label for="stato">Stato </label>
<button type="submit">LED D0</button>
</form>
<form action="https://api.particle.io/v1/devices/***/d7?access_token=***" method="POST">
<button type="submit">LED D7</button>
</form>
<form action="https://api.particle.io/v1/devices/***/setalarm?access_token=***" method="POST">
<label for="stato">Stato</label>
<input id='stato' type="number" name="arg">
<button type="submit">BEEP </button>
</form></body></html>
no one knows why?
Hi @onide! I wish I could help, but I’m unfamiliar with Adobe PhoneGap. As your html appears to be working without issue, I don’t suspect that this is an issue with the Particle API or with the call itself. I recommend bringing the issue to the PhoneGap Community. I’m happy to give any advice I can from the Particle side during that process.
HI,
I don’t have a clue about this but I did some research and I was able to run my function on photon just from WordPad. I just changed and added one thing:
instead of :
try this:
<form action="https://api.particle.io/v1/devices/your_device_label/your_function_name?" method="POST">
<input type="hidden" name="access_token" value="your_access_token"/>
</form>
results:
light on comand
light on resp.
light off comand
light off response
also I disabled Two-Factor Authentication to test this, i’m not sure if will work with mfa enabled
It should work with 2FA without issue! I’m happy to hear you were able to make this work through another means.
It’s my pleasure :smile:
harder challenge, better challenge :open_hands:
I hope I helped somehow by the way , i’m learned today that I can run my functions get variables just with notepad on my phone :+1:
thank you all. i’ll try when i return in office.
