Then Spark Core LED starts flash cyan - Spark Core is not connected to Wifi, co it can not even try to connect to cloud - that status indication is wrong and should be fixed.
During short Wifi connected interval Spark Core manages to set IP via DHCP.
The most recent posts in that thread are from December of this year, so it seemed like it could be relevant. Maybe we can narrow down what specific configuration is causing the issue. Are you using a very long key per-chance?
I have not been able to put Spark core into operation on Mikrotik Wifi connectivity.
Problem is somehow related to Spark core because other TI CC3000 modules connets without problems. Unfortunately there is not enough informative debug/troubleshoot info available in current implementation from Spark core to figure out what is going on during connectivity problems in Spark core/CC3000.
I have issues with Spark core connectivity on corporate Cisco Wifi APs with Cisco Wireless Controller, from Cisco debug info it seams there are some timeout values setup issues in Spark core.
It semas there is not enough users in Spark core community to fix issues on enterprise wifi setups, so I discontinued Spark core pilot unfortunately and I am using other vendor modules now.
