Hi All,
I’m playing with IoT Central, and for bringing something to life in an ultra light speed way, IoT Central is pretty solid… Except for the fact that IoT Central doesn’t give you access to the underlying IoT Hub config / settings within your IoT Central project. Therefore, one can not find the IoT Hub Name or Shared Access Policy name to point the Particle Azure Integration to.
It’s in Particle / MS’s best interest to make this integration work. Anyone out there find a way to figure out there IoT Central Hub Name / Shared access policy name?
Jon
