I try to build the mdns.ino example with the mDNS library from Particle Build. If I target for 0.6.1 it compiles successfully but in 0.6.2 it gives an error.
Googling didn’t give me any clue how to fix this and I’m also curious why this breaks in 0.6.2.
Build errors: /workspace/lib/MDNS/src/Record.h:143:44: error: converting to 'String' from initializer list would use explicit constructor 'String::String(int, unsigned char)' void addEntry(String key, String value = NULL);
/workspace/lib/MDNS/src/MDNS.h:24:47: error: converting to 'String' from initializer list would use explicit constructor 'String::String(int, unsigned char)' void addTXTEntry(String key, String value = NULL);
@mrhornsby You seem to maintain this library, maybe you have an idea?
I’ve not tried compiling this in a while. Having a look through the release notes mentions something about arduino compatibility and including the Arduino.h header. Given that the compilation failures are against the signatures in the headers as well this could be related - can you try adding the Arduino.h header and see if that resolves the issue?
Hi Mark,
I’ve tried adding #include "Arduino.h" on top of the example file. Because I think I can’t edit libraries in Particle build (and offline it works…).
This threw an additional error. So there might be a bug in the online builder?
../wiring/inc/spark_wiring_arduino_constants.h:111:18: error: expected unqualified-id before '(' token #define max(a,b) ((a)>(b)?(a):(b))
@mrhornsby Thanks for updating the code. Did you also synchronised it with Particle (particle library upload and particle library publish <my_lib> ? Because the build still gives the old version.
I’ve uploaded a new version (1.3.2) that handles the old format (String x = NULL) but defaults to an empty string. This will work on v0.6.2 and should have exactly the same behaviour as before.
I get another error with 1.3.2 in build: /workspace//src/mdns.cpp:1:18: fatal error: MDNS.h: No such file or directory #include "application.h" ^
It think you should include Particle.h nowadays.
Yup, I have noticed this behaviour too. After adding a library you sometimes get this message but a few seconds or edits later it builds fine. Just as if adding the library takes its time to trickle through to your project
Another question. I’ve noticed I couldn’t reach my host “myphoton.local” anymore, while it gave back a success.
I removed the addService line, after that I could reach my server again. Putting the line back after that again, and now I can reach myphoton still good.
So this is a kind of non-producable bug. I’m curious what it could be and how I possibly can prevent it.
