Is there an easy way to get the local toolchain to compile .ino files? Would it also be possible for the preprocessor to be applied?
The preprocessor can be found here: https://github.com/spark/buildpack-wiring-preprocessor
@nrobinson2000, there is no pre-processor on the local toolchain.
But is it possible to treat a .ino as c++ in make?
@nrobinson2000, make only accepts cpp and c files as far as I know. You would need to rename or make a copy with a .cpp extension for compiling.
That’s what I thought.
