M1E Adapter - 4 Pin
I got a Particle w/ the Audio Board. It's got a 4 pin header that I believe is expected to be soldered into the M1E Adapter board. How is it intended to be installed? Pins up/sockets down to match the M1E board or Pins down/sockets up?
This audio adapter? It should have a flat FFC cable that does not require soldering.
