I may need to migrate from the P2 to the M-SOM to get both WiFi and Cellular here in North America. Am I correct in looking through the products for sale that there is not currently a dev board for this module until November 2024?
That is correct for the M.2 SoM breakout board.
If you are an enterprise customer, there may be some samples available.
You can use the older M.2 SoM evaluation board with the M-SoM with limitations, namely that you need to use an external 9-12V power supply or a battery, as the older evaluation board does not provide sufficient current for the M-SoM when powered by USB.
