I’m working on a product where we’ve implemented the P1 onto some custom hardware into a product. We have 4 devices that have been working well, until here the other day when the WiFi router broke down.
Of course, when the WiFi disappears, the p1 won’t connect. But the problem is that it’s impossible to give them new wifi credentials.
I get the devices into Setup mode with the LED blinking blue. And I can use the Particle app and find the devices via “Setup new Photon”. But after selecting the new WiFi router and entering the password I get the following error:
“Setup process couldn’t configure the WiFi credentials for your photon…”
I’ve tried connecting via the command line interface and serial connection using ‘particle serial wifi’ command. It finds the correct access point, but when I choose it, it just freezes and nothing more happens.
This has happened with 4 devices now.
I tried running the ‘particle update’ command - and even though it runs and completes without errors, it’s still not possible to get the device to connect to a new access point.
I’ve found that by running the particle doctor, I am able to fix the problem. So I am not looking for a way to fix the problem, I am looking for a way to avoid the problem in the future as this is going to be a product that goes out to customers - and it’s going to happen that customers lose their wifi now and then.
I’ve reproduced the error after getting the device connected to the new wifi router by disconnecting the wifi router. Now trying to set it up with a new wifi router, I get the same error as above.
I ran the ‘particle update’ yesterday (1st of May 2018) so the devices should have the latest Device OS release. We did not have this problem before, so I guess it’s either a bug in the latest device os release or a firmware problem. But I have no idea what to look for.
