Greetings! I am trying to reflash an ESP8266 (via http://www.instructables.com/id/Turn-a-Cheap-WiFi-Plug-Into-an-OpenHAB-ESP8266-Swi/) but I seem to have lost my USB to TTL Serial Adapter.
I have an unused Particle Photon that I bought a few months ago for a different project.
Can the Photon be used to flash the firmware on the ESP? If so, any thoughts about how I might go about it? I’m really new about this stuff!
Thanks tons!
I’m just about to do the same thing with this code
SYSTEM_MODE(MANUAL)
Serial1.begin(115200);
Serial.begin(115200);
while(Serial.available())
Serial1.write(Serial.read());
while(Serial1.available())
Serial.write(Serial1.read());
Give it a try.
@ScruffR Thanks for that bit of code! I will keep track of it for later. I got sidetracked on that current project and in getting sidetracked I found me USB TTL adapter! Thank you though for your thoughtfulness and time.
This works perfectly! Great for debugging other dev kits that does not have a USB serial out.
