Today Losant released a direct Particle Integration. Behind the scenes Losant is subscribing to Particle’s streaming events API and will trigger workflows whenever your devices publish an event.
This allows you to integrate Particle and Losant without any additional configuration in the Particle Console. You simply publish events as you normally would and then tell Losant which events you’d like to use as triggers.
We’re excited at the number of developers using Particle and Losant together. If you have additional requests to make the integration better, please let me know!
