Lookup binaries.particle.io: i/o timeout
I can't get past this. I have done a manual uninstall of Node, NPM and Particle CLI with no resolution.
I have scoured the forums, but the resolution evades me and I have no idea what comes next.
I'm running a MacBook Pro M.1 and Terminal is running under Rosetta. The actions from inside VC Code, Workbench also fail, as one would expect.
2023/08/26 19:06:34 Time since last update 15m36.626639546s, update in block
2023/08/26 19:06:34 particle: Adding dependencies...
2023/08/26 19:06:35
2023/08/26 19:06:35 ▸ Get "https://binaries.particle.io/node/v16.20.0/node-v16.20.0-darwin-x64.tar.gz": dial tcp: lookup binaries.particle.io: i/o timeout
2023/08/26 19:06:35
2023/08/26 19:06:35 ▸ Error rebuilding packages.
▸ Try running again with GODE_DEBUG=info to see more output.
2023/08/26 19:06:35 done
2023/08/26 19:06:35 particle: Installing plugins...
2023/08/26 19:06:35
2023/08/26 19:06:35
2023/08/26 19:06:35 ▸ fork/exec bin/node: no such file or directory
2023/08/26 19:06:35 particle: Installing plugins (retrying)...
2023/08/26 19:06:35
2023/08/26 19:06:35 ▸ Error installing package.
Really? No one has any advice.
Well, never mind. I found a post on stack overflow from someone who did the following:
From a non-Rosetta termianal, run
brew uninstall --force node
brew uninstall --force npm
then
brew install node
Now particle-cli works just fine in Rosetta. I am concerned with the fact that I have to run in Rosetta and with such old node/npm code.
