Hello,
I have a Particle Core which I used with the cloud before/ I have been trying to move from the cloud to a local server and was able to do so. There is a great guide by Kenneth that has the whole process laid out. After that initial experiment I wanted to take the core back to the cloud and reverted the certificates back to the original ones but now when I try to connect it flashes cyan likes its trying to connect then flashes red for a bit and repeats it over and over.
I was thinking that maybe I could reinstall the whole firmware to get it to factory settings and then try again the local and cloud swap to see if it can be done on demand.
Where can I find the latest firmware to install it on the micro?
Any hints, tips, suggestions are welcomed.
Thank you,
Hector
