I hope somebody can help I’ve been banging my head for a bit trying to solve this.
- I tried to get the local sever running
- Installed the new key using: spark keys server
- I ran into some problems and attempted to revert back to the cloud server
- I am stuck now with the flashing cyan super fast - I believe this is because it can’t connect to the cloud server
- I think it’s because it still has local server key
Is there any way ver the CLI that I can get this set up to use the key for the cloud? Basically I want to revert back.
Thanks for any help
Hey @pixelboy,
There’s a tutorial to guide you along for Local
: https://community.spark.io/t/tutorial-local-cloud-1st-time-instructions/5589/10
Look at the bottom of the tutorial, I have included instructions as to how to switch back to the Spark
Thank you @kennethlimcp… that did it. I just spent hours looking for the solution. In case anybody else runs into the same thing here are the steps…
Download this file…
https://s3.amazonaws.com/spark-website/cloud_public.der
cd to the directory you downloaded it too.
Place your core in DFU-mode (flashing yellow)
enter the following on the command line.
spark keys server cloud_public.der
Note: this step to revert back should be added to github!
