Does this mean we have to call
Particle: Launch Compiler Shellonce after starting VSCode?
no, we want this to be easy ![]()
Particle: Launch Compiler Shell is just an interactive version of the environment our local compilation tasks run in - if it works, local compilation should as well.
try this:
- run the
Particle: Create Projectcommand (ctrl/cmd+shift+p then type “particle” and select from the list) and follow the prompts. upon completion, your new workspace should be loaded. - run the
Particle: Configure Workspace for Devicecommand and select the Device OS version and your hardware platform (e.g.deviceOS@0.7.0andphotonor if you are using our new Gen 3 hw,deviceOS@0.8.0-rc.25andargon, etc). depending on your selection, you may see additional dependencies start to download & install. - write or import some basic “hello world” code in the
./src/<your project name>.inofile within your workspace - from the main menu bar select: “Terminal > Run Task…” and run one of the compilation or flash tasks (e.g.
Particle: Compile application (local)) - connect your device and put it into DFU-mode (docs)
- select “Terminal > Run Task…” and run the
Particle: Flash application (local)task.
your new firmware should be flashed and your device should restart where you can verify your program is running as expected.
if you run into problems, can you note the step from the list above where the problem occurred?
