Library problems
I have been writting some code for my word clock. All was fine until last night, when I started getting errors relating to the libraries and their presence or otherwise. The clock is a long strip of neo pixels. I have included the neopixel library. I have had this code working for some days but then it just stopped and started giving me the followinf error,
word_clock_2.cpp:14:31: fatal error: neopixel/neopixel.h: No such file or directory
'#include "neopixel/neopixel.h"
compilation terminated.
make: *** [word_clock_2.o] Error 1
The first bit of my code is as follows,
'#include "application.h"
//#include "spark_disable_wlan.h" (for faster local debugging only)
// IMPORTANT: Set pixel COUNT, PIN and TYPE
'#define PIXEL_PIN D2
'#define PIXEL_COUNT 107
'#define PIXEL_TYPE WS2812B
Any ideas what is going on?
I thought I had solved it last night by cutting the exact same code from this app and putting it into a newly created app. This worked but only for a short time.
Any ideas?
Any help would be much appreciated :wink:
Julian
Hi @Julian
I think a few people are having problems with that right now and @Dave is investigating.
Hi Julian, Sorry to hear of the problems. There have been a few other reports of vanishing libraries, and the spark IDE team are looking at it. In the meantime, a workaround is to remove the library from your app and then add it again. That will get compilation working.
Indeed, sorry about the troubles @Julian , we are actively investigating this now. Could you PM me the app build URLs where the problem you described above occurred (i.e. https://www.spark.io/build/SOME_ID_HERE), so I can look more closely at the underlying logs, events, and database while troubleshooting this issue?
@bko @mdma @jgoggins,
Thank you very much for your quick response. I thought it was just me!
I am sure with you lot on the case it will get sorted out pretty soon.
Cheers,
Julian
