Library for communicating with Lego Bluetooth
Hi
I am per today controlling a lego bluetooth train with the help of the library Lpf2Hub.h, all done on wemos lolin d32 via arduino ide.
Is it possible to use this on a particle argon etc, or does it need to be ported?
Cheers //
It needs to be ported because the bluetooth stack on Particle devices is different from the one in ESP32. If you are referring to this library, I started the porting work few months ago but a bug in Particle’s BLE stack prevented me from making progress. Haven’t tried again, it’s possible it’s fixed now.
That is precisely the one I am referring to. Was thinking about switching to a particle chip instead for iot-functionality and getting rid of that usb-cable for programming.
This topic was automatically closed 60 days after the last reply. New replies are no longer allowed.
