I do it first. I will use the sparkcore to make an automatic curtain. And I can use wifi to adjust the brightness threshold. I will take advantage of my Easy Power(really easy and cheap) as well.
What about your ideas?
Have you noticed this topic? There are already many interesting ideas and someone else is actually planning same kind of project than yours.
Thanks for your reminding. When I submited the topic, I already found the problem.
