When I flash fresh the firmware works fine
but when I reset the particle photon the laser does not work.
I am opening serial connection to the U81 distance sensor laser
const int powerUp1 = D6;
byte cont_fast[] = { 0xAA, 0x00, 0x00, 0x20, 0x00, 0x01, 0x00, 0x06, 0x27 };
byte cont_exit[] = { 0x58 };
int secAlive = 20;//number of seconds to keep on reading
int secPassedSinceTrigger = 0;
int minR = 0;
int maxR = 0;
int avgR = 0;
unsigned int hexadecimalToDecimal(String hexString) {
unsigned int decValue = 0;
int nextInt;
for (int i = 0; i < hexString.length(); i++) {
nextInt = int(hexString.charAt(i));
if (nextInt >= 48 && nextInt <= 57) nextInt = map(nextInt, 48, 57, 0, 9);
if (nextInt >= 65 && nextInt <= 70) nextInt = map(nextInt, 65, 70, 10, 15);
if (nextInt >= 97 && nextInt <= 102) nextInt = map(nextInt, 97, 102, 10, 15);
nextInt = constrain(nextInt, 0, 15);
decValue = (decValue * 16) + nextInt;
return decValue;
String write_cont_fast() {
//digitalWrite(powerUp1, HIGH);
int secPrev = Time.local() % 86400;
bool waitUntilTimeUp = true;
while(waitUntilTimeUp){
Serial1.write(cont_fast, sizeof(cont_fast));
delay(1000);//let the command execute
int bytesAvailable = Serial1.available();
byte bytes[bytesAvailable];
int hexCounter = 0;
Serial1.readBytes((char*)bytes, bytesAvailable);
String output;
bool IsDataValid = false;
for (int i = 0; i < bytesAvailable; i++) {
String data = String(bytes[i], HEX);
if(i==0 && data=="aa"){
IsDataValid = true;
if(data.length()==1){
data = "0" + data;
if (i >= 8 && i <= 9) {
output = output + data;
if(IsDataValid){
int milimeters = hexadecimalToDecimal(output);
//float inches = milimeters * 0.0393701;
if(milimeters<minR || minR==0){
minR = milimeters;
if(milimeters>maxR){
maxR = milimeters;
avgR = (minR + maxR)/2;
CloudPublish("OUTPUT-min", String(33.37-(minR* 0.0393701)));
CloudPublish("OUTPUT-max", String(33.37-(maxR* 0.0393701)));
CloudPublish("OUTPUT-avg", String(33.37-(avgR* 0.0393701)));
int secNow = Time.local() % 86400;
secPassedSinceTrigger = secNow - secPrev;
if(secPassedSinceTrigger >= secAlive){
Serial1.write(cont_exit, sizeof(cont_exit));
//digitalWrite(powerUp1, LOW);
String write_cont_exit() {
//Serial1.write("X");
//Serial1.write(cont_exit, sizeof(cont_exit));
//delay(500);//let the command execute
void CloudPublish(String key, String value) {
Particle.publish(key, value);
pinMode(powerUp1, OUTPUT);
Serial1.begin(19200, SERIAL_8N1);
write_cont_fast();
write_cont_exit();
CloudPublish("OUTPUT-min", String(minR* 0.0393701));
CloudPublish("OUTPUT-max", String(maxR* 0.0393701));
CloudPublish("OUTPUT-avg", String(avgR* 0.0393701));
minR = 0;
maxR = 0;
avgR = 0;
