Labview questions
Has anyone had any luck gettion a photon to connect to labview via the sub vi's as suggested in the reference.There is no documentation that I can find other than .....here it is.... use it to connect to particle. When I put in my login /PW i get an error
Scan From String (arg 1) in Particle API.lvlib:Read Access Token.vi->Particle API.lvlib:Open Connection.vi
ideas???
s
Let me ping someone that might be able to help, @rickkas7 or @ParticleD are you able to assist?
