Issue with 6.3.0 for B404X Still Showing 1024 Instead of 16K+
I am using a B404X and running into an issue where the maximum event size remains at 1024 bytes, despite the updated documentation indicating it should be 16K+.
Code Example:
Particle.publish("eventDataSize", String(Particle.maxEventDataSize()));
However, when I run this, the reported event data size is still 1024 bytes, not the expected larger value.
Is there something I'm missing, or is there an additional configuration required to enable the larger event size on the B404X?
Any insights would be greatly appreciated!
Hey Graham,
I think we need to use the brand new extended publish:
There is a new type of publish and stuff, I just read it.
Best,
Hi Gus,
I will have to dive into the new Cloud Event update I was under the impression the traditional Particle.publish() would include an increase in the event size based on the documentation. Thanks!
hey, yes I was under the same impression but reading today the docs made me realize there might be new stuff we need to use.
Cheers,
Sorry, added notes that using the CloudEvent API is required to use large and high rate publish.
