[ISSUE] Facing import issue with (LoRa) libraries on workbench
Hey!
I am new to particle boards, and I have been messing around with the boron for a few days. I have been using the workbench for most of the flashing to save some data.
However, whenever I was trying out the LoRa example code from RF9X-RK and RH_RF95, I get a lot of errors. I tried it on a mac and a windows laptop and I'm facing the same issue. I don't know why - but I'm guessing it is probably due to some path settings. Can someone help me figure this out?
Here is the audit:
    "username": "XXX",
    "workspace": {
        "name": "Blink_LED",
        "isWorkspace": false,
        "folders": [
                "location": "c:\\Users\\CS\\Documents\\Workspace\\Boron_V1.5_Test\\Blink_LED",
                "hasValidPath": true,
                "settings": {
                    "firmwareName": "deviceOS",
                    "firmwareVersion": "4.0.2",
                    "targetDevice": "Boron_V1.5_1",
                    "targetPlatform": "boron",
                    "compileButtonAction": "localAppDeviceOS",
                    "flashButtonAction": "localAppDeviceOS",
                    "disableWelcomeScreen": false,
                    "disableDeviceOSOutdatedCheck": false,
                    "disableLocalCompilerDirtyCheck": false,
                    "enableVerboseLocalCompilerLogging": false,
                    "compileDefines": [],
                    "customDeviceOSLocation": "",
                    "maxAllowedToolchains": 4
                "files": [
                    ".vscode",
                    ".vscode\\launch.json",
                    ".vscode\\settings.json",
                    "boron_firmware_1685630684670.bin",
                    "lib",
                    "lib\\CryptoLW-RK",
                    "lib\\RF9X-RK",
                    "project.properties",
                    "README.md",
                    "src",
                    "src\\Blink_LED.txt",
                    "src\\server.cpp",
                    "src\\server.ino",
                    "target",
                    "target\\4.0.2"
    "cli": {
        "binpath": "c:\\Users\\CS\\.vscode\\extensions\\particle.particle-vscode-core-1.16.1\\src\\cli\\bin\\windows\\amd64\\particle.exe",
        "ok": true,
        "version": "3.11.0",
        "installed": 1685039975467
    "localCompiler": {
        "ok": false,
        "dependencies": [
                "id": "deviceOS@4.0.2",
                "ok": true
                "id": "gcc-arm@10.2.1",
                "ok": true
                "id": "buildtools@1.1.1",
                "ok": true
                "id": "buildscripts@1.11.0",
                "ok": true
                "id": "openocd@0.11.0-particle.4",
                "ok": true
                "id": "deviceOS@2.0.0-rc.3",
                "ok": true
                "id": "gcc-arm@9.2.1",
                "ok": true
                "id": "deviceOS@1.5.2",
                "ok": true
                "id": "gcc-arm@5.3.1",
                "ok": true
    "platform": {
        "os": "windows",
        "type": "Windows_NT",
        "release": "10.0.19045",
        "arch": "x64",
        "path": {
            "key": "Path",
            "value": "C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\Intel\\Intel(R) Management Engine Components\\DAL;C:\\Program Files\\Intel\\Intel(R) Management Engine Components\\DAL;C:\\Program Files (x86)\\Intel\\Intel(R) Management Engine Components\\IPT;C:\\Program Files\\Intel\\Intel(R) Management Engine Components\\IPT;C:\\Program Files\\MATLAB\\R2018b\\bin;C:\\Users\\CS\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\CS\\AppData\\Local\\particle\\bin;C:\\OpenSSL-Win32\\bin;{\"properties\":{\"Status\":\"Success\"},\"event\":\"Install Done\",\"context\":{\"os\":{\"name\":\"Windows\",\"version\":\"10.0 (64 bit)\"}},\"anonymousId\":\"laptop-bhg1tvbe\\\\cs S-1-5-21-526588647-2124628400-2262313652-1002\\r\\n\"};C:\\Users\\CS\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;",
            "entries": [
                "C:\\WINDOWS\\system32",
                "C:\\WINDOWS",
                "C:\\WINDOWS\\System32\\Wbem",
                "C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\",
                "C:\\WINDOWS\\System32\\OpenSSH\\",
                "C:\\Program Files (x86)\\Intel\\Intel(R) Management Engine Components\\DAL",
                "C:\\Program Files\\Intel\\Intel(R) Management Engine Components\\DAL",
                "C:\\Program Files (x86)\\Intel\\Intel(R) Management Engine Components\\IPT",
                "C:\\Program Files\\Intel\\Intel(R) Management Engine Components\\IPT",
                "C:\\Program Files\\MATLAB\\R2018b\\bin",
                "C:\\Users\\CS\\AppData\\Local\\Microsoft\\WindowsApps",
                "C:\\Users\\CS\\AppData\\Local\\particle\\bin",
                "C:\\OpenSSL-Win32\\bin",
                "{\"properties\":{\"Status\":\"Success\"},\"event\":\"Install Done\",\"context\":{\"os\":{\"name\":\"Windows\",\"version\":\"10.0 (64 bit)\"}},\"anonymousId\":\"laptop-bhg1tvbe\\\\cs S-1-5-21-526588647-2124628400-2262313652-1002\\r\\n\"}",
                "C:\\Users\\CS\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
        "homeDir": "C:\\Users\\CS",
        "particleDir": "C:\\Users\\CS\\.particle",
        "particleToolchainDir": "C:\\Users\\CS\\.particle\\toolchains"
    "env": {
        "ALLUSERSPROFILE": "C:\\ProgramData",
        "APPDATA": "C:\\Users\\CS\\AppData\\Roaming",
        "CHROME_CRASHPAD_PIPE_NAME": "\\\\.\\pipe\\LOCAL\\crashpad_5396_GORYRYNJFQNDSDWJ",
        "COMPUTERNAME": "LAPTOP-BHG1TVBE",
        "ComSpec": "C:\\WINDOWS\\system32\\cmd.exe",
        "CommonProgramFiles": "C:\\Program Files\\Common Files",
        "CommonProgramFiles(x86)": "C:\\Program Files (x86)\\Common Files",
        "CommonProgramW6432": "C:\\Program Files\\Common Files",
        "DriverData": "C:\\Windows\\System32\\Drivers\\DriverData",
        "ELECTRON_RUN_AS_NODE": "1",
        "FPS_BROWSER_APP_PROFILE_STRING": "Internet Explorer",
        "FPS_BROWSER_USER_PROFILE_STRING": "Default",
        "HOMEDRIVE": "C:",
        "HOMEPATH": "\\Users\\CS",
        "LOCALAPPDATA": "C:\\Users\\CS\\AppData\\Local",
        "LOGONSERVER": "\\\\LAPTOP-BHG1TVBE",
        "NUMBER_OF_PROCESSORS": "4",
        "OPENSSL_CONF": "C:\\OpenSSL-Win32\\bin\\openssl.cfg",
        "ORIGINAL_XDG_CURRENT_DESKTOP": "undefined",
        "OS": "Windows_NT",
        "OneDrive": "C:\\Users\\CS\\OneDrive",
        "OnlineServices": "Online Services",
        "PATHEXT": ".COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC",
        "PROCESSOR_ARCHITECTURE": "AMD64",
        "PROCESSOR_IDENTIFIER": "Intel64 Family 6 Model 142 Stepping 10, GenuineIntel",
        "PROCESSOR_LEVEL": "6",
        "PROCESSOR_REVISION": "8e0a",
        "PSModulePath": "C:\\Program Files\\WindowsPowerShell\\Modules;C:\\WINDOWS\\system32\\WindowsPowerShell\\v1.0\\Modules",
        "PUBLIC": "C:\\Users\\Public",
        "Path": "C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\Intel\\Intel(R) Management Engine Components\\DAL;C:\\Program Files\\Intel\\Intel(R) Management Engine Components\\DAL;C:\\Program Files (x86)\\Intel\\Intel(R) Management Engine Components\\IPT;C:\\Program Files\\Intel\\Intel(R) Management Engine Components\\IPT;C:\\Program Files\\MATLAB\\R2018b\\bin;C:\\Users\\CS\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\CS\\AppData\\Local\\particle\\bin;C:\\OpenSSL-Win32\\bin;{\"properties\":{\"Status\":\"Success\"},\"event\":\"Install Done\",\"context\":{\"os\":{\"name\":\"Windows\",\"version\":\"10.0 (64 bit)\"}},\"anonymousId\":\"laptop-bhg1tvbe\\\\cs S-1-5-21-526588647-2124628400-2262313652-1002\\r\\n\"};C:\\Users\\CS\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;",
        "ProgramData": "C:\\ProgramData",
        "ProgramFiles": "C:\\Program Files",
        "ProgramFiles(x86)": "C:\\Program Files (x86)",
        "ProgramW6432": "C:\\Program Files",
        "RegionCode": "NA",
        "SESSIONNAME": "Console",
        "SystemDrive": "C:",
        "SystemRoot": "C:\\WINDOWS",
        "TEMP": "C:\\Users\\CS\\AppData\\Local\\Temp",
        "TMP": "C:\\Users\\CS\\AppData\\Local\\Temp",
        "USERDOMAIN": "LAPTOP-BHG1TVBE",
        "USERDOMAIN_ROAMINGPROFILE": "LAPTOP-BHG1TVBE",
        "USERNAME": "CS",
        "USERPROFILE": "C:\\Users\\CS",
        "VSCODE_AMD_ENTRYPOINT": "vs/workbench/api/node/extensionHostProcess",
        "VSCODE_CODE_CACHE_PATH": "C:\\Users\\CS\\AppData\\Roaming\\Code\\CachedData\\b3e4e68a0bc097f0ae7907b217c1119af9e03435",
        "VSCODE_CRASH_REPORTER_PROCESS_TYPE": "extensionHost",
        "VSCODE_CRASH_REPORTER_SANDBOXED_HINT": "1",
        "VSCODE_CWD": "C:\\Users\\CS\\AppData\\Local\\Programs\\Microsoft VS Code",
        "VSCODE_HANDLES_UNCAUGHT_ERRORS": "true",
        "VSCODE_IPC_HOOK": "\\\\.\\pipe\\364b6576818cac6376f8d77e5a3eb769-1.78.2-main-sock",
        "VSCODE_L10N_BUNDLE_LOCATION": "",
        "VSCODE_NLS_CONFIG": "{\"locale\":\"en-us\",\"osLocale\":\"en-us\",\"availableLanguages\":{},\"_languagePackSupport\":true}",
        "VSCODE_PID": "5396",
        "platformcode": "KV",
        "windir": "C:\\WINDOWS"
    "versions": {
        "node": "16.17.1",
        "v8": "10.8.168.25-electron.0",
        "uv": "1.43.0",
        "zlib": "1.2.12.1-motley",
        "brotli": "1.0.9",
        "ares": "1.18.1",
        "modules": "110",
        "nghttp2": "1.47.0",
        "napi": "8",
        "llhttp": "6.0.9",
        "openssl": "1.1.1",
        "cldr": "41.0",
        "icu": "71.1",
        "tz": "2023a",
        "unicode": "14.0",
        "electron": "22.5.2",
        "microsoft-build": "20762381",
        "chrome": "108.0.5359.215"
    "vscode": {
        "appName": "Visual Studio Code",
        "appRoot": "c:\\Users\\CS\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
        "machineId": "643e496b0e78fc7978688b943d7595f2ae3c3e02c32b0f5e80849e39020aee5c",
        "sessionId": "ea4922b1-fc64-46d5-9f4d-81e378370fbf1685478590746",
        "version": "1.78.2"
    "extensions": [
            "id": "ms-vscode-remote.remote-wsl-recommender",
            "version": "0.0.19"
            "id": "ms-vscode.js-debug",
            "version": "1.78.0"
            "id": "ms-vscode.js-debug-companion",
            "version": "1.0.18"
            "id": "ms-vscode.node-debug",
            "version": "1.44.28"
            "id": "ms-vscode.node-debug2",
            "version": "1.42.7"
            "id": "ms-vscode.references-view",
            "version": "0.0.80"
            "id": "ms-vscode.vscode-js-profile-table",
            "version": "1.0.3"
            "id": "marus25.cortex-debug",
            "version": "1.10.0"
            "id": "mcu-debug.debug-tracker-vscode",
            "version": "0.0.15"
            "id": "mcu-debug.memory-view",
            "version": "0.0.20"
            "id": "mcu-debug.rtos-views",
            "version": "0.0.6"
            "id": "ms-vscode.cpptools",
            "version": "1.15.4"
            "id": "particle.particle-vscode-core",
            "version": "1.16.1"
            "id": "particle.particle-vscode-pack",
            "version": "1.16.1"
            "id": "particle.particle-vscode-snippets",
            "version": "1.16.1"
            "id": "particle.particle-vscode-theme",
            "version": "1.16.1"
You should check out the project here.
They've taken my RF9X-RK library and forked it any they're maintaining it.
However the actual compile errors you are getting would be helpful, along which which version of Device OS you are targeting, and whether you are using a cloud or local compile.
Thanks for the information, I'll definitely check that out!
I got it working when I flashed the code via the web IDE, but I'm still getting an error in workbench when I do a local flash (w/ cloud compile.)
I also get the squiggly lines in vscode.
Configuration: boron, 4.02
Here is the log:
 *  Executing task: make -f '/Users/pranav/.particle/toolchains/buildscripts/1.11.0/Makefile' flash-all -s
:::: PUTTING DEVICE INTO DFU MODE
Done.
:::: FLASHING APPLICATION & DEVICE OS
  /Users/pranav/.particle/toolchains/deviceOS/4.0.2/modules/boron/system-part1/makefile /Users/pranav/.particle/toolchains/deviceOS/4.0.2/modules/boron/user-part/makefile
   text    data     bss     dec     hex filename
 508320    2638   61900  572858   8bdba ../../../build/target/system-part1/platform-13-m/system-part1.elf
Serial device PARTICLE_SERIAL_DEV : not available
Flashing using dfu:
dfu-util 0.9
ID 2b04:d00d
Claiming USB DFU Interface...
dfuIDLE, continuing
Downloading to address = 0x00030000, size = 510962
Download        [=========================] 100%       510962 bytes
Download done.
File downloaded successfully
Creating /Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/target/4.0.2/boron/platform_user_ram.ld ...
/Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/CryptoLW-RK/src/Speck.cpp:107:5: warning: "USE_AVR_INLINE_ASM" is not defined, evaluates to 0 [-Wundef]
  107 | #if USE_AVR_INLINE_ASM
/Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/CryptoLW-RK/src/Speck.cpp:305:5: warning: "USE_AVR_INLINE_ASM" is not defined, evaluates to 0 [-Wundef]
  305 | #if USE_AVR_INLINE_ASM
/Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/CryptoLW-RK/src/Speck.cpp:427:5: warning: "USE_AVR_INLINE_ASM" is not defined, evaluates to 0 [-Wundef]
  427 | #if USE_AVR_INLINE_ASM
/Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/CryptoLW-RK/src/SpeckSmall.cpp:100:5: warning: "USE_AVR_INLINE_ASM" is not defined, evaluates to 0 [-Wundef]
  100 | #if USE_AVR_INLINE_ASM
/Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/CryptoLW-RK/src/SpeckSmall.cpp:263:5: warning: "USE_AVR_INLINE_ASM" is not defined, evaluates to 0 [-Wundef]
  263 | #if USE_AVR_INLINE_ASM
/Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/CryptoLW-RK/src/SpeckTiny.cpp:111:5: warning: "USE_AVR_INLINE_ASM" is not defined, evaluates to 0 [-Wundef]
  111 | #if USE_AVR_INLINE_ASM
/Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/CryptoLW-RK/src/SpeckTiny.cpp:158:5: warning: "USE_AVR_INLINE_ASM" is not defined, evaluates to 0 [-Wundef]
  158 | #if USE_AVR_INLINE_ASM
In file included from /Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/RF9X-RK/src/RHGenericDriver.h:9,
                 from /Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/RF9X-RK/src/RHDatagram.h:9,
                 from /Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/RF9X-RK/src/RHDatagram.cpp:6:
/Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/RF9X-RK/src/RadioHead.h:320:51: warning: "/*" within comment [-Wcomment]
  320 | cp /usr/local/projects/arduino/libraries/RadioHead/*.h .
/Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/RF9X-RK/src/RadioHead.h:321:51: warning: "/*" within comment [-Wcomment]
  321 | cp /usr/local/projects/arduino/libraries/RadioHead/*.cpp .
/Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/RF9X-RK/src/RadioHead.h:1174: warning: "SPI_HAS_TRANSACTION" redefined
 1174 |   #define SPI_HAS_TRANSACTION
In file included from ./inc/application.h:95,
                 from ./inc/Particle.h:5,
                 from /Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/RF9X-RK/src/RadioHead.h:1166,
../wiring/inc/spark_wiring_arduino.h:76: note: this is the location of the previous definition
   76 | #define SPI_HAS_TRANSACTION (1)
/Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/RF9X-RK/src/RadioHead.h:1379:96: warning: "TEENSYDUINO" is not defined, evaluates to 0 [-Wundef]
 1379 | #if (RH_PLATFORM == RH_PLATFORM_ARDUINO && ARDUINO >= 155 && !defined(RH_PLATFORM_ATTINY)) || (TEENSYDUINO && defined(__MK20DX128__))
                 from /Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/RF9X-RK/src/RHEncryptedDriver.h:15,
                 from /Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/RF9X-RK/src/RHEncryptedDriver.cpp:7:
/Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/RF9X-RK/src/RHEncryptedDriver.cpp: In member function 'virtual bool RHEncryptedDriver::send(const uint8_t*, uint8_t)':
/Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/RF9X-RK/src/RHEncryptedDriver.cpp:62:36: warning: comparison of integer expressions of different signedness: 'size_t' {aka 'unsigned int'} and 'int' [-Wsign-compare]
   62 |     if (_cipheringBlocks.blockSize != blockSize)
/Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/RF9X-RK/src/RHEncryptedDriver.cpp:71:13: warning: unused variable 'nbBlocks' [-Wunused-variable]
   71 |     uint8_t nbBlocks = len / blockSize + 1; // How many blocks do we need for that message
                 from /Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/RF9X-RK/src/RHGenericDriver.cpp:6:
In file included from /Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/RF9X-RK/src/RHGenericSPI.h:10,
                 from /Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/RF9X-RK/src/RHGenericSPI.cpp:7:
                 from /Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/RF9X-RK/src/RHHardwareSPI.h:10,
                 from /Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/RF9X-RK/src/RHHardwareSPI.cpp:7:
                 from /Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/RF9X-RK/src/RHReliableDatagram.h:10,
                 from /Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/RF9X-RK/src/RHReliableDatagram.cpp:14:
                 from /Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/RF9X-RK/src/RHSPIDriver.h:9,
                 from /Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/RF9X-RK/src/RHSPIDriver.cpp:6:
                 from /Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/RF9X-RK/src/RH_RF95.h:15,
                 from /Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/lib/RF9X-RK/src/RH_RF95.cpp:6:
                 from /Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/src/server.ino:8:
                 from /Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test//src/server.cpp:5:
/Users/pranav/.particle/toolchains/gcc-arm/10.2.1/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld: ../../../build/target/user/platform-13-m/LoRa-Test//libuser.a(lora_1.o): in function `setup':
/Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/src/lora_1.ino:4: multiple definition of `setup'; ../../../build/target/user/platform-13-m/LoRa-Test//libuser.a(candle.o):/Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/src/candle.ino:7: first defined here
/Users/pranav/.particle/toolchains/gcc-arm/10.2.1/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld: ../../../build/target/user/platform-13-m/LoRa-Test//libuser.a(lora_1.o): in function `loop':
/Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/src/lora_1.ino:8: multiple definition of `loop'; ../../../build/target/user/platform-13-m/LoRa-Test//libuser.a(candle.o):/Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/src/candle.ino:13: first defined here
/Users/pranav/.particle/toolchains/gcc-arm/10.2.1/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld: ../../../build/target/user/platform-13-m/LoRa-Test//libuser.a(server.o): in function `setup':
/Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/src/server.ino:30: multiple definition of `setup'; ../../../build/target/user/platform-13-m/LoRa-Test//libuser.a(candle.o):/Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/src/candle.ino:7: first defined here
/Users/pranav/.particle/toolchains/gcc-arm/10.2.1/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld: ../../../build/target/user/platform-13-m/LoRa-Test//libuser.a(server.o): in function `loop':
/Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/src/server.ino:69: multiple definition of `loop'; ../../../build/target/user/platform-13-m/LoRa-Test//libuser.a(candle.o):/Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/src/candle.ino:13: first defined here
make[2]: *** [/Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test/target/4.0.2/boron/LoRa-Test.elf] Error 1
make[1]: *** [/Users/pranav/.particle/toolchains/deviceOS/4.0.2/modules/boron/user-part/makefile] Error 2
make: *** [flash-all] Error 2
 *  The terminal process "/bin/bash '-c', 'make -f '/Users/pranav/.particle/toolchains/buildscripts/1.11.0/Makefile' flash-all -s'" terminated with exit code: 2.
 *  Press any key to close the terminal.
That's not really an error, it's just Intellisense not detecting the library header files. See this post for steps you can try to get Intellisense to recognize the libraries, or just ignore it.
Here is the audit from the mac:
    "username": "XXX",
    "workspace": {
        "name": "LoRa-Test",
        "folders": [
                "location": "/Users/pranav/Documents/Workspace/IoT/LoRa/LoRa-Test",
                "settings": {
                    "targetDevice": "Boron_V1.5_2",
                "files": [
                    ".vscode",
                    ".vscode/launch.json",
                    ".vscode/settings.json",
                    "README.md",
                    "boron_firmware_1685635223447.bin",
                    "lib",
                    "lib/CryptoLW-RK",
                    "lib/RF9X-RK",
                    "src",
                    "src/server.cpp",
                    "src/server.ino",
                    "target",
                    "target/4.0.2"
    "cli": {
        "binpath": "/Users/pranav/.vscode/extensions/particle.particle-vscode-core-1.16.1/src/cli/bin/darwin/amd64/particle",
        "ok": true,
        "installed": 1685459288498
    "localCompiler": {
        "ok": true,
        "dependencies": [
                "ok": true
                "ok": true
                "ok": true
                "ok": true
                "ok": true
    "platform": {
        "os": "darwin",
        "type": "Darwin",
        "release": "22.5.0",
        "arch": "x64",
        "path": {
            "key": "PATH",
            "value": "/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin",
            "entries": [
                "/usr/local/bin",
                "/System/Cryptexes/App/usr/bin",
                "/usr/bin",
                "/bin",
                "/usr/sbin",
                "/sbin",
                "/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin",
                "/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin",
                "/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin"
        "homeDir": "/Users/pranav",
        "particleDir": "/Users/pranav/.particle",
        "particleToolchainDir": "/Users/pranav/.particle/toolchains"
    "env": {
        "COMMAND_MODE": "unix2003",
        "HOME": "/Users/pranav",
        "LOGNAME": "pranav",
        "MallocNanoZone": "0",
        "OLDPWD": "/",
        "PATH": "/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin",
        "PWD": "/",
        "SHELL": "/bin/zsh",
        "SHLVL": "0",
        "SSH_AUTH_SOCK": "/private/tmp/com.apple.launchd.YthepsjJVx/Listeners",
        "TMPDIR": "/var/folders/74/s14crl2107qc9n_qdbnk79b40000gn/T/",
        "USER": "pranav",
        "VSCODE_CODE_CACHE_PATH": "/Users/pranav/Library/Application Support/Code/CachedData/b3e4e68a0bc097f0ae7907b217c1119af9e03435",
        "VSCODE_CWD": "/",
        "VSCODE_IPC_HOOK": "/Users/pranav/Library/Application Support/Code/1.78-main.sock",
        "VSCODE_PID": "1137",
        "XPC_FLAGS": "0x0",
        "XPC_SERVICE_NAME": "application.com.microsoft.VSCode.87078.87084",
        "_": "/Applications/Visual Studio Code.app/Contents/MacOS/Electron",
        "__CFBundleIdentifier": "com.microsoft.VSCode",
        "__CF_USER_TEXT_ENCODING": "0x1F5:0x0:0x0",
    "versions": {
        "node": "16.17.1",
        "uv": "1.43.0",
        "brotli": "1.0.9",
        "ares": "1.18.1",
        "modules": "110",
        "napi": "8",
        "llhttp": "6.0.9",
        "openssl": "1.1.1",
        "cldr": "41.0",
        "icu": "71.1",
        "tz": "2023a",
        "unicode": "14.0",
    "vscode": {
        "appRoot": "/Applications/Visual Studio Code.app/Contents/Resources/app",
        "machineId": "1f8357c3333dc8056d64580408655af1195d993823357fe419b1824a0a13b899",
        "sessionId": "dc17f7fe-47cc-4a03-b3e9-396a96e139241685625691986",
        "version": "1.78.2"
    "extensions": [
            "version": "1.78.0"
            "version": "1.0.18"
            "version": "1.0.3"
            "id": "GitHub.copilot",
            "version": "1.87.127"
            "id": "Kelvin.vscode-sshfs",
            "version": "1.26.1"
            "version": "1.10.0"
            "version": "0.0.15"
            "version": "0.0.20"
            "version": "0.0.6"
            "id": "ms-python.python",
            "version": "2023.8.0"
            "id": "ms-python.vscode-pylance",
            "version": "2023.5.50"
            "version": "1.15.4"
            "version": "1.16.1"
            "version": "1.16.1"
            "version": "1.16.1"
            "version": "1.16.1"
            "id": "shd101wyy.markdown-preview-enhanced",
            "version": "0.6.8"
That totally fixed, thank you so much!
