Using VSCode on Windows 11. Had no problem doing local debug using Particle Debugger with Boron module.
Switched to B404 module and can’t start debugging session. This window pops up:
and debug console reports:
Reading symbols from C:/Users/chida/.particle/toolchains/gcc-arm/10.2.1/bin/arm-none-eabi-objdump.exe --syms -C -h -w c:/MyData/EQR/Particle/B40x/alertv2_3/target/5.3.0/bsom/alertv2_3.elf
Reading symbols from c:/users/chida/.particle/toolchains/gcc-arm/10.2.1/bin/arm-none-eabi-nm.exe --defined-only -S -l -C -p c:/MyData/EQR/Particle/B40x/alertv2_3/target/5.3.0/bsom/alertv2_3.elf
Launching GDB: “C:\Users\chida\.particle\toolchains\gcc-arm\10.2.1\bin\arm-none-eabi-gdb.exe” -q --interpreter=mi2
IMPORTANT: Set “showDevDebugOutput”: “raw” in “launch.json” to see verbose GDB transactions here. Very helpful to debug issues or report problems
Launching gdb-server: “C:\Users\chida\.particle\toolchains\openocd\0.11.0-particle.4\bin\openocd.exe” -c “gdb_port 50000” -c “tcl_port 50001” -c “telnet_port 50002” -s “C:\Users\chida\.particle\toolchains\openocd\0.11.0-particle.4\share\openocd\scripts” -f “c:/Users/chida/.vscode/extensions/marus25.cortex-debug-1.10.0/support/openocd-helpers.tcl” -f “interface\cmsis-dap.cfg” -f “target\nrf52-particle.cfg”
Please check TERMINAL tab (gdb-server) for output from C:\Users\chida.particle\toolchains\openocd\0.11.0-particle.4\bin\openocd.exe
Finished reading symbols from objdump: Time: 53 ms
Finished reading symbols from nm: Time: 76 ms
OpenOCD: GDB Server Quit Unexpectedly. See gdb-server output in TERMINAL tab for more details.
Terminal tab shows:
Waiting for gdb server to start…[2023-04-04T19:17:21.688Z] SERVER CONSOLE DEBUG: onBackendConnect: gdb-server session connected. You can switch to “DEBUG CONSOLE” to see GDB interactions.
xPack OpenOCD x86_64 Open On-Chip Debugger 0.11.0+dev (2022-03-25-17:32)
Licensed under GNU GPL v2
For bug reports, read
OpenOCD: Bug Reporting
CDRTOSConfigure
Info : auto-selecting first available session transport “swd”. To override use ‘transport select ’.
DEPRECATED! use ‘adapter speed’ not ‘adapter_khz’
Info : Listening on port 50001 for tcl connections
Info : Listening on port 50002 for telnet connections
Error: unable to find a matching CMSIS-DAP device
[2023-04-04T19:17:21.815Z] SERVER CONSOLE DEBUG: onBackendConnect: gdb-server session closed
GDB server session ended. This terminal will be reused, waiting for next session to start…
Is there any tutorial on how to debug a B40x module? The only one I’ve found is for a Boron, and that was very old…
