Is there a spark.xxx function that detects if wifi is within reach?
I would like to use my Spark Core device to detect if my car is home. The idea is to only enable my dash camera’s while driving and also parking. The latter is done through an auxiliary battery. In both situations a relay in this aux circuitry needs to be switched on or off pending WIFI connect. Obviously I’m adding more function to this later 8-). Peter
You mighth simply check for spark.connected() - it returns true if the spark is connected, e…g if you are in reach of your home network.
http://docs.spark.io/#/firmware/cloud-spark-connected
There was a great discussion on using the Core to scan for wifi networks in range, you could also use that to detect when you are home:
David
