Is the Particle Pi 3 no longer being offered as a kit?
I’ve been looking for the Particle Pi kit in the store, but there are no links. The documentation seems to exist.
Is this kit no longer offered? If not, what would be the best option to replicate the kit?
I believe it is not on the Particle Store because Adafruit (the supplier of the kit) is out of stock of the kits.
https://www.adafruit.com/categories/105
You can still buy the Raspberry Pi 3 and the parts of the kit on Adafruit. To replicate the kit you would need the Pi 3 itself, SD card, power supply, breadboard, a cobbler https://www.adafruit.com/products/2028 and components to use.
You could also get this very well compiled kit from Canakit:
