Is it safe to wear a photon
Hi all,
If I conceal a Photon inside a glove or a sock in a way that it’s very close to the skin - am I in danger of being exposed to to unhealthy levels of radiation?
Is there a way to reduce the radiation? Should I add a lead plate into my design?
I’m so new to this… Any input would be much appreciated!
cheers,
ith
Do you use a mobile phone? If yes, and you don’t use special precautions, then yes, it’s safe :wink:
