Is it possible to delete firmware versions from a product
It does not appear to be possible to delete old versions of product firmware which I don’t need any more, at least not from the web ui.
Even if that firmware is not used by any device in the product fleet, and will never be in future since I’ve released enhanced versions now.
Am I missing something obvious?
It can’t be deleted. If the firmware has never been released, you can delete it, but once you release it, it can’t be deleted, even if it’s not currently running on any device in your fleet.
The console should probably allow you to delete firmware that’s not used by any device in your product, but that’s not the way it works right now.
