Is it necessary an external watchdog timer for improving reliability?
I will use my particle electron outside for monitoring CO2 gases. , but it is indispensable for me maintaining a stable connection.
I saw
I tried a long time to get devices working without an external watchdog - but I’d also put the TPL5010 in all my designs. If energy is a critical measure you can put your electron in SYSTEM_MODE(manual) and wake up your electron every x-minutes just to reset the watchdog timer, until your duty cycle has reached,…
EDIT: I use the implemented software-watchdog already, but in some cases this WD fails,…
Would you mind if you could give me an example of SW watchdog timer?
https://docs.particle.io/reference/firmware/electron/#application-watchdog
