Somehow i’m in
with old school stuff and this Nokia LCD is cute and compact!
I have everything hooked up and its working well so the next step is to figure out the webhooks setup so that I can pull in the Air-quality index and view it easily!
Here’s the github repo: https://github.com/kennethlimcp/nokia-iot
So i am trying to extract the data from the dataset here:
<channel>
<title>PM2.5 Update</title>
<source>Airviro</source>
<item>
<region>
<id>rNO</id>
<latitude>1.41803</latitude>
<longitude>103.82000</longitude>
<record timestamp="20150919220000">
<reading type="PM25_RGN_1HR" value="42"/>
</record>
</region>
<region>
<id>rCE</id>
<latitude>1.35735</latitude>
<reading type="PM25_RGN_1HR" value="43"/>
</record>
</region>
<region>
<id>rEA</id>
<longitude>103.94000</longitude>
<reading type="PM25_RGN_1HR" value="52"/>
</record>
</region>
<region>
<id>rWE</id>
<longitude>103.70000</longitude>
</record>
</region>
<region>
<id>rSO</id>
<latitude>1.29587</latitude>
<reading type="PM25_RGN_1HR" value="57"/>
</record>
</region>
</item>
</channel>
Using a simple .indexOf() search function, i managed to extract information for rNO and rEA (2 hook response from webhook`) but the other 2 data set is missing due to the way i am processing the response.
Any suggestion on how i can extract them efficiently?
I need the:
<id>rNO</id>
<reading type="PM25_RGN_1HR" value="42"/> (only the number 42)
breezometer.com has a free API that gives JSON responses so you could use a Response Template and filter down to the exact data you want. No need to extract, just tokenize and reuse the data to display on the screen. I am fan of this method because I am not so good with extract and it culls the data to minimum needed.
@LukeUSMC thanks cool!
But this dataset is from Singapore’s agency and it’s more accurate to the hour. I appreciate your inputs though!
Fair enough. Here is a XML to JSON proxy service that you could route the call through…
XML to JSON Proxy
Here is another using Google Feed API
XML to JSON using Google Feed API
If you can’t tell…I am a HUGE fan of JSON and loath XML and the parsing mess it creates! One response, nothing but the data you want and no parsing. Doesn’t get much better than that!
