Some community users are reporting intermittent connection to the
If you are experiencing similar issues, please bear with us while the Spark team is notified and replies with an official report.
Devices unable to connect
Investigating - The ops team is responding.
Feb 2, 08:27 CST
Resolved - There was a problem with the device service's database connections. Everything's back online now.
Feb 2, 08:39 CST
Thanks for re-posting here Kenneth!
You guys rock!
I just received a new Spark Core, and am now experiencing intermittent connectivity. The device maintains a connection to the cloud for about 45 seconds or so, and then the red LED flashes and the core goes offline.
I have found this to be the case whether or not the device is near the router, and whether or not it is powered by a PC through USB (as opposed to a wall adapter).
Any thoughts? Could this somehow be related to the original issue in this thread?
@NickOveracker, are you running your own app on the Core or just out-of-the-box Tinker?
My own app. It works fine on an older core that I got from the first shipment ages ago.
But, I’ll try flashing Tinker and see if anything changes.
Edit: It’s interesting to note that I wasn’t able to claim the Core with my phone, even though I was able to connect it to the cloud. I had to claim it manually.
@peekay123: Tinker seems to work fine. Then, there is something about my program that causes it to disconnect, but I can’t imagine what.
I do make use of a delay function, but the maximum delay is about 12 microseconds… not enough to cause connectivity issues.
Some of the inputs are disconnected (high-impedance). Could attempting to read these inputs cause any trouble? This is the only difference between this Core and the old Core I was using.
Snipped and reposted as a new topic.
