Hi there!
Is anyone else impacted by today's (2/22/2024) AT&T (and others) outage? I am in the North Texas area and my devices are not connecting (green/blue flashing). The Particle dashboard says "all clear" but other outlets say otherwise.
Hi there!
We've seen recovery and devices have resumed normal connectivity. What are you seeing on Cloud Debug | Troubleshooting | Particle?
@Support can you take a look?
CHRIS hahahah you rock!
Currently I'm seeing:
Serial monitor opened successfully:
0000001317 [mux] INFO: Stopping GSM07.10 muxer
0000001317 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000001317 [mux] INFO: Closing all muxed channels
0000001318 [mux] INFO: Muxed channel 1 already closed
0000001318 [mux] INFO: Muxed channel 2 already closed
0000001319 [mux] INFO: Muxed channel 3 already closed
0000001319 [mux] INFO: Muxed channel 4 already closed
0000001320 [mux] INFO: Sending CLD (multiplexer close down)
0000002220 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000002270 [mux] INFO: GSM07.10 muxer thread exiting
0000002270 [mux] INFO: GSM07.10 muxer stopped
0000002285 [ncp.client] INFO: Using internal SIM card
0000003395 [mux] INFO: Starting GSM07.10 muxer
0000003396 [mux] INFO: Opening mux channel 0
0000003397 [mux] INFO: GSM07.10 muxer thread started
0000003399 [mux] INFO: Opening mux channel 1
and it stops there. If you want me to continue and flash Cloud Doctor on one of the devices I can.
Alright, with the Cloud Doctor firmware installed it connects.
0000001131 [ncp.at] TRACE: < +CCID: 89883070000037330709
0000001132 [ncp.at] TRACE: < OK
0000001133 [ncp.at] TRACE: > AT+UMNOPROF?
0000001138 [ncp.at] TRACE: < +UMNOPROF: 100
0000001138 [ncp.at] TRACE: < OK
0000001139 [ncp.at] TRACE: > AT+UBANDMASK?
0000001144 [ncp.at] TRACE: < +UBANDMASK: 0,6170,0
0000001145 [ncp.at] TRACE: < OK
0000001145 [ncp.at] TRACE: > AT+COPS=3,2
0000001149 [ncp.at] TRACE: < OK
0000001150 [ncp.at] TRACE: > AT+CGEREP=1,0
0000001153 [ncp.at] TRACE: < OK
0000001154 [ncp.at] TRACE: > AT+URAT?
0000001157 [ncp.at] TRACE: < +URAT: 7
0000001158 [ncp.at] TRACE: < OK
0000001159 [ncp.at] TRACE: > AT+CPSMS?
0000001164 [ncp.at] TRACE: < +CPSMS: 0,,,"00010011","00000011"
0000001164 [ncp.at] TRACE: < OK
0000001165 [ncp.at] TRACE: > AT+CEDRXS?
0000001170 [ncp.at] TRACE: < +CEDRXS: 4,"0000"
0000001171 [ncp.at] TRACE: < OK
0000001171 [mux] INFO: Mux channel 1 already opened
0000001172 [ncp.at] TRACE: > AT
0000001176 [ncp.at] TRACE: < OK
0000001176 [ncp.client] TRACE: NCP state changed: 1
0000001177 [net.pppncp] TRACE: NCP event 1
0000001179 [app] INFO: cellular is on
0000001181 [ncp.at] TRACE: > AT+CCID
0000001206 [ncp.at] TRACE: < +CCID: 89883070000037330709
0000001206 [ncp.at] TRACE: < OK
0000001208 [ncp.at] TRACE: > AT+CGMI
0000001212 [ncp.at] TRACE: < u-blox
0000001214 [ncp.at] TRACE: < OK
0000001216 [ncp.at] TRACE: > AT+CGMM
0000001219 [ncp.at] TRACE: < SARA-R510S
0000001221 [ncp.at] TRACE: < OK
0000001223 [ncp.at] TRACE: > AT+CGMR
0000001226 [ncp.at] TRACE: < 03.15
0000001227 [ncp.at] TRACE: < OK
0000001229 [ncp.at] TRACE: > AT+CGSN
0000001233 [ncp.at] TRACE: < 351457832089681
0000001233 [ncp.at] TRACE: < OK
> 0000010001 [app] INFO: Platform: Boron
0000010001 [app] INFO: Binary compiled for: 4.0.1
0000010002 [app] INFO: Troubleshooting firmware version 12
0000010003 [app] INFO: System version: 4.0.1
0000010004 [app] INFO: Device ID: e00fce68cc263c50da1df815
0000010005 [app] INFO: Connecting to the cloud
0000010089 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
0000010092 [net.ppp.client] TRACE: PPP thread event ADM_UP data=0
0000010092 [net.ppp.client] TRACE: State NONE -> READY
0000010095 [ncp.at] TRACE: > AT+CFUN?
0000010097 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
0000010099 [ncp.at] TRACE: < +CFUN: 1,7
0000010100 [ncp.at] TRACE: < OK
0000010101 [ncp.at] TRACE: > AT+CCID
0000010124 [ncp.at] TRACE: < +CCID: 89883070000037330709
0000010125 [ncp.at] TRACE: < OK
0000010126 [ncp.at] TRACE: > AT+CGDCONT?
0000010132 [ncp.at] TRACE: < +CGDCONT: 1,"IP","super.mnc010.mcc234.gprs","100.70.20.148",0,0,0,2,0,0,0,0,0,0,0
0000010133 [ncp.at] TRACE: < OK
0000010134 [ncp.at] TRACE: > AT+CFUN?
0000010137 [ncp.at] TRACE: < +CFUN: 1,7
0000010138 [ncp.at] TRACE: < OK
0000010139 [ncp.at] TRACE: > AT+CEREG=2
0000010142 [ncp.at] TRACE: < OK
0000010142 [ncp.client] TRACE: NCP connection state changed: 1
0000010143 [net.pppncp] TRACE: NCP event 2
0000010144 [net.pppncp] TRACE: State changed event: 1
0000010145 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0000010145 [ncp.at] TRACE: > AT+COPS?
0000010150 [ncp.at] TRACE: < +COPS: 0,2,"310410",7
0000010150 [ncp.at] TRACE: < OK
0000010151 [ncp.at] TRACE: > AT+CEREG?
0000010156 [ncp.at] TRACE: < +CEREG: 2,5,"6a41","07f3a20f",7
0000010156 [ncp.at] TRACE: < OK
0000010157 [ncp.client] TRACE: NCP connection state changed: 2
0000010158 [mux] INFO: Openning mux channel 2
0000010491 [net.pppncp] TRACE: NCP event 100
0000010492 [net.pppncp] TRACE: New auth info
0000010495 [net.pppncp] TRACE: NCP event 2
0000010495 [net.pppncp] TRACE: State changed event: 2
0000010496 [ncp.at] TRACE: > AT+CIMI
0000010497 [net.ppp.client] TRACE: PPP thread event LOWER_UP data=0
0000010497 [net.ppp.client] TRACE: State READY -> CONNECT
0000010498 [net.ppp.client] TRACE: State CONNECT -> CONNECTING
0000010544 [ncp.at] TRACE: < 234104869428767
0000010545 [ncp.at] TRACE: < OK
0000010546 [ncp.at] TRACE: > AT+CGATT?
0000010549 [ncp.at] TRACE: < +CGATT: 1
0000010550 [ncp.at] TRACE: < OK
0000011551 [ncp.at] TRACE: > AT
0000011554 [ncp.at] TRACE: < OK
0000011555 [ncp.at] TRACE: > AT+UPORTFWD=100,1
0000011559 [ncp.at] TRACE: < +UPORTFWD: 100,1
0000011559 [ncp.at] TRACE: < OK
0000011560 [ncp.at] TRACE: > ATD*99***1#
0000011566 [ncp.at] TRACE: < CONNECT
0000011566 [net.ppp.client] TRACE: PPP phase -> Initialize
0000011568 [net.ppp.client] TRACE: PPP phase -> Establish
0000011568 [lwip.ppp] TRACE: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x5852213f> <pcomp> <accomp>]
0000011571 [lwip.ppp] TRACE: rcvd [LCP ConfReq id=0x0 <asyncmap 0x0> <mru 1360> <auth pap> <accomp> <pcomp>]
0000011572 [lwip.ppp] TRACE: sent [LCP ConfAck id=0x0 <asyncmap 0x0> <mru 1360> <auth pap> <accomp> <pcomp>]
0000011583 [lwip.ppp] TRACE: rcvd [LCP ConfAck id=0x1 <asyncmap 0x0> <magic 0x5852213f> <pcomp> <accomp>]
0000011584 [lwip.ppp] TRACE: sent [LCP EchoReq id=0x0 magic=0x5852213f]
0000011585 [net.ppp.client] TRACE: PPP phase -> Authenticate
0000011586 [lwip.ppp] TRACE: sent [PAP AuthReq id=0x1 user="" password=""]
0000011595 [lwip.ppp] TRACE: rcvd [LCP EchoRep id=0x0 magic=0x0]
0000011598 [lwip.ppp] TRACE: rcvd [PAP AuthAck id=0x1 "Login successful."]
0000011598 [net.ppp.client] TRACE: PPP phase -> Network
0000011600 [lwip.ppp] TRACE: sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <msdns1 8.8.8.8> <msdns2 8.8.4.4>]
0000011602 [lwip.ppp] TRACE: rcvd [IPCP ConfReq id=0x0 <addr 192.168.201.2>]
0000011603 [lwip.ppp] TRACE: sent [IPCP ConfNak id=0x0 <addr 192.168.201.2>]
0000011611 [lwip.ppp] TRACE: rcvd [IPCP ConfNak id=0x1 <addr 192.168.201.1> <msdns1 8.8.4.4> <msdns2 8.8.8.8>]
0000011613 [lwip.ppp] TRACE: sent [IPCP ConfReq id=0x2 <addr 192.168.201.1> <msdns1 8.8.4.4> <msdns2 8.8.8.8>]
0000011615 [lwip.ppp] TRACE: rcvd [IPCP ConfReq id=0x1 <addr 192.168.201.2>]
0000011616 [lwip.ppp] TRACE: sent [IPCP ConfAck id=0x1 <addr 192.168.201.2>]
0000011625 [lwip.ppp] TRACE: rcvd [IPCP ConfAck id=0x2 <addr 192.168.201.1> <msdns1 8.8.4.4> <msdns2 8.8.8.8>]
0000011626 [system.nm] INFO: State changed: IFACE_UP -> IFACE_LINK_UP
0000011628 [net.ppp.client] TRACE: PPP thread event UP data=0
0000011628 [net.ppp.client] TRACE: State CONNECTING -> CONNECTED
0000011629 [net.pppncp] TRACE: Negotiated MTU: 1360
0000011628 [system.nm] INFO: State changed: IFACE_LINK_UP -> IP_CONFIGURED
0000011631 [net.ppp.client] TRACE: PPP phase -> Running
0000011633 [system] INFO: Cloud: connecting
0000011638 [system] WARN: Failed to load session data from persistent storage
0000012173 [system] INFO: Cloud socket connected
0000012173 [comm.protocol.handshake] INFO: Establish secure connection
0000012185 [comm.dtls] INFO: (CMPL,RENEG,NO_SESS,ERR) restoreStatus=2
0000013021 [comm.protocol.handshake] INFO: Sending HELLO message
0000013176 [comm.protocol.handshake] INFO: Handshake completed
0000013176 [comm.protocol.handshake] TRACE: Updating cached session parameters
0000013178 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0000013180 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 3
0000013566 [ncp.at] TRACE: > AT+CFUN?
0000013569 [ncp.at] TRACE: < +CFUN: 1,7
0000013570 [ncp.at] TRACE: < OK
0000013571 [ncp.at] TRACE: > AT+CCID
0000013615 [ncp.at] TRACE: < +CCID: 89883070000037330709
0000013616 [ncp.at] TRACE: < OK
0000013616 [ncp.at] TRACE: > AT+CGSN
0000013621 [ncp.at] TRACE: < 351457832089681
0000013621 [ncp.at] TRACE: < OK
0000013622 [ncp.at] TRACE: > ATI9
0000013626 [ncp.at] TRACE: < 03.15,A00.01
0000013627 [ncp.at] TRACE: < OK
0000013650 [comm.protocol] INFO: Sending subscriptions
0000013831 [comm.protocol] TRACE: Reply recieved: type=2, code=0
0000013831 [comm.protocol] TRACE: message id 5 complete with code 0.00
0000013833 [comm.protocol] TRACE: rcv'd message type=13
0000013842 [comm.protocol] TRACE: Reply recieved: type=2, code=0
0000013842 [comm.protocol] TRACE: message id 2 complete with code 0.00
0000013844 [comm.protocol] TRACE: Updating system DESCRIBE checksum
0000013845 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0000014240 [ncp.at] TRACE: > AT+CFUN?
0000014244 [ncp.at] TRACE: < +CFUN: 1,7
0000014246 [ncp.at] TRACE: < OK
0000014248 [ncp.at] TRACE: > AT+CCID
0000014274 [ncp.at] TRACE: < +CCID: 89883070000037330709
0000014276 [ncp.at] TRACE: < OK
0000014278 [ncp.at] TRACE: > AT+CGSN
0000014282 [ncp.at] TRACE: < 351457832089681
0000014282 [ncp.at] TRACE: < OK
0000014284 [ncp.at] TRACE: > ATI9
0000014287 [ncp.at] TRACE: < 03.15,A00.01
0000014289 [ncp.at] TRACE: < OK
0000014289 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 3
0000014291 [comm.protocol] TRACE: rcv'd message type=13
0000014293 [comm.protocol] TRACE: Reply recieved: type=2, code=0
0000014295 [comm.protocol] TRACE: message id 3 complete with code 0.00
0000014295 [comm.protocol] TRACE: rcv'd message type=13
0000014397 [comm.protocol] TRACE: Reply recieved: type=2, code=0
0000014397 [comm.protocol] TRACE: message id 4 complete with code 0.00
0000014399 [comm.protocol] TRACE: rcv'd message type=13
0000014501 [comm.protocol] TRACE: Reply recieved: type=2, code=0
0000014501 [comm.protocol] TRACE: message id 7 complete with code 0.00
0000014503 [comm.protocol] TRACE: Updating application DESCRIBE checksum
0000014505 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0000014507 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 3
0000014507 [comm.protocol] TRACE: rcv'd message type=13
0000014609 [comm.protocol] TRACE: Reply recieved: type=2, code=69
0000014609 [comm.protocol] TRACE: message id 6 complete with code 2.05
0000014611 [comm.protocol] INFO: Received TIME response: 1708622604
0000014613 [comm.protocol] TRACE: rcv'd message type=12
0000014713 [comm.protocol] TRACE: Reply recieved: type=2, code=0
0000014713 [comm.protocol] TRACE: message id 8 complete with code 0.00
0000014715 [comm.protocol] TRACE: rcv'd message type=13
0000014816 [comm.protocol] TRACE: Reply recieved: type=2, code=0
0000014816 [comm.protocol] TRACE: message id 9 complete with code 0.00
0000014818 [comm.protocol] TRACE: Updating subscriptions checksum
0000014820 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0000014822 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 3
0000014822 [comm.protocol] TRACE: rcv'd message type=13
0000014924 [system] INFO: Cloud connected
0000014925 [ncp.at] TRACE: > AT+COPS=3,2
0000014929 [ncp.at] TRACE: < OK
0000014930 [ncp.at] TRACE: > AT+COPS?
0000014934 [ncp.at] TRACE: < +COPS: 0,2,"310410",7
0000014934 [ncp.at] TRACE: < OK
0000014935 [ncp.at] TRACE: > AT+CEREG?
0000014940 [ncp.at] TRACE: < +CEREG: 2,5,"6a41","07f3a20f",7
0000014941 [ncp.at] TRACE: < OK
0000014941 [app] INFO: Cellular Info: cid=133407247 lac=27201 mcc=310 mnc=410
0000014943 [ncp.at] TRACE: > AT+CFUN?
0000014946 [ncp.at] TRACE: < +CFUN: 1,7
0000014947 [ncp.at] TRACE: < OK
0000014948 [ncp.at] TRACE: > AT+CCID
0000014971 [ncp.at] TRACE: < +CCID: 89883070000037330709
0000014972 [ncp.at] TRACE: < OK
0000014973 [ncp.at] TRACE: > AT+CGSN
0000014977 [ncp.at] TRACE: < 351457832089681
0000014977 [ncp.at] TRACE: < OK
0000014978 [ncp.at] TRACE: > ATI9
0000014981 [ncp.at] TRACE: < 03.15,A00.01
0000014982 [ncp.at] TRACE: < OK
0000014983 [ncp.at] TRACE: > AT+CGED=3
0000014986 [ncp.at] TRACE: < ERROR
0000015000 [ncp.at] TRACE: > AT+COPS=3,2
0000015003 [ncp.at] TRACE: < OK
0000015004 [ncp.at] TRACE: > AT+COPS?
0000015008 [ncp.at] TRACE: < +COPS: 0,2,"310410",7
0000015008 [ncp.at] TRACE: < OK
0000015009 [ncp.at] TRACE: > AT+CEREG?
0000015014 [ncp.at] TRACE: < +CEREG: 2,5,"6a41","07f3a20f",7
0000015015 [ncp.at] TRACE: < OK
0000015016 [ncp.at] TRACE: > AT+CFUN?
0000015020 [ncp.at] TRACE: < +CFUN: 1,7
0000015021 [ncp.at] TRACE: < OK
0000015022 [ncp.at] TRACE: > AT+CCID
0000015045 [ncp.at] TRACE: < +CCID: 89883070000037330709
0000015046 [ncp.at] TRACE: < OK
0000015047 [ncp.at] TRACE: > AT+CGSN
0000015051 [ncp.at] TRACE: < 351457832089681
0000015051 [ncp.at] TRACE: < OK
0000015052 [ncp.at] TRACE: > ATI9
0000015055 [ncp.at] TRACE: < 03.15,A00.01
0000015056 [ncp.at] TRACE: < OK
0000015057 [ncp.at] TRACE: > AT+CGED=3
0000015060 [ncp.at] TRACE: < ERROR
0000015060 [app] INFO: Cellular Info: cid=133407247 lac=27201 mcc=310 mnc=410
0000015122 [comm.protocol] TRACE: rcv'd message type=8
0000015192 [comm.protocol] INFO: Received DESCRIBE request; flags: 0x04
0000015196 [ncp.at] TRACE: > AT+COPS=3,2
0000015200 [ncp.at] TRACE: < OK
0000015202 [ncp.at] TRACE: > AT+COPS?
0000015207 [ncp.at] TRACE: < +COPS: 0,2,"310410",7
0000015209 [ncp.at] TRACE: < OK
0000015209 [ncp.at] TRACE: > AT+UCGED?
0000015697 [ncp.at] TRACE: < +UCGED: 2
0000015698 [ncp.at] TRACE: < 6,4,310,410
0000015699 [ncp.at] TRACE: < 5110,12,50,50,6a41,7f3a20f,198,d5bdabc1,ff30,b1,50,16,0.93,3,255,255,49,4,-15,300,255,255,80
0000015700 [ncp.at] TRACE: < OK
0000015703 [ncp.at] TRACE: > AT+COPS=3,2
0000015705 [ncp.at] TRACE: < OK
0000015707 [ncp.at] TRACE: > AT+COPS?
0000015711 [ncp.at] TRACE: < +COPS: 0,2,"310410",7
0000015711 [ncp.at] TRACE: < OK
0000015713 [ncp.at] TRACE: > AT+CEREG?
0000015718 [ncp.at] TRACE: < +CEREG: 2,5,"6a41","07f3a20f",7
0000015720 [ncp.at] TRACE: < OK
0000015724 [comm.protocol] TRACE: rcv'd message type=1
0000015897 [comm.protocol] TRACE: Reply recieved: type=2, code=0
0000015897 [comm.protocol] TRACE: message id 10 complete with code 0.00
0000015899 [comm.protocol] TRACE: rcv'd message type=13
I'm going to go back and flash my firmware. This scares me a little, though, if I have to do this to get connectivity - that shouldn't be the case I'm sure!
Okay, something is not right - I went back and recompiled and flashed my firmware. It is not connecting.
I don't know if I was interpreting cloud doctors output correctly, but its definitely hung on trying to connect.
0000001497 [app] INFO: loop
0000001900 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000001950 [mux] INFO: GSM07.10 muxer thread exiting
0000001950 [mux] INFO: GSM07.10 muxer stopped
0000001951 [mux] INFO: Starting GSM07.10 muxer
0000001952 [mux] INFO: GSM07.10 muxer thread started
0000002251 [mux] INFO: Stopping GSM07.10 muxer
0000002251 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000002252 [mux] INFO: Closing all muxed channels
0000002252 [mux] INFO: Muxed channel 1 already closed
0000002252 [mux] INFO: Muxed channel 2 already closed
0000002253 [mux] INFO: Muxed channel 3 already closed
0000002253 [mux] INFO: Muxed channel 4 already closed
0000002254 [mux] INFO: Sending CLD (multiplexer close down)
0000002497 [app] INFO: loop
0000003155 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000003205 [mux] INFO: GSM07.10 muxer thread exiting
0000003205 [mux] INFO: GSM07.10 muxer stopped
0000003498 [app] INFO: loop
0000004498 [app] INFO: loop
0000005498 [app] INFO: loop
0000006499 [app] INFO: loop
0000007499 [app] INFO: loop
0000008499 [app] INFO: loop
0000009499 [app] INFO: loop
0000010207 [ncp.client] ERROR: No response from NCP
0000010407 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
I am using a Boron 404X with 5.7.0.
12PM Central update - devices are beginning to connect on standard firmware. I think there's lingering issues with the AT&T network at least in North Texas. I'll report if things go south again.
5PM Central update - looks like the national "outage" for AT&T has ended, and my devices are connecting. Events like these always make me revisit SLAs and business continuity plans!
Glad to hear things are back to normal.
While it happens - it's fortunately rare that the carriers drop the ball like they did yesterday.
