IFTTT Not working anymore
I am no longer able to use IFTTT after I was successfully able to use it with another project. I went to create a new small project and cannot interact with IFTTT. I did notice that it is no longer the Spark channel, but rather the Particle channel. I disconnected and reconnected to the particle channel. My function are showing up, but i cannot get them to trigger when sending a text to them, like I could in the past.
I have read the posts regarding the fix and have tried everything on there with no luck. Any help will be much appreciated. Code below. THANK YOU!!
    int relay = D1;
int lightOn(String command);
int lightOff(String command);
int led = D4;
    Spark.function("on", lightOn);
    Spark.function("off", lightOff);
    pinMode(relay, OUTPUT);
    pinMode(led, OUTPUT);
    digitalWrite(relay,HIGH);
    delay(2000);
    digitalWrite(relay, LOW);
        if(command == "on")
            digitalWrite(led,HIGH);
        if(command == "off")
            digitalWrite(led,LOW);
Please use this format to post code in discourse:
``` <-- insert this code
//paste code here
Try recreating the recipe again.
Thank you for your reply. I have tried a couple times. Even tried signing out and signing in, also tried clearing core and running setup again.
Hi @danlee6992,
Make sure your Spark.functions return a value, and that your device is online. Can you tell me any more about your recipe, or when it wasn’t working? I can check the logs and try to see what’s up. :slight_smile:
David
Thank you Dave!! After a few frustrating hours, I removed the function parameter to what the parameter I was passing in through IFTTT and got rid of the if statement. That seemed to work.
This is the new code that worked:
My apologies if it’s not formatted as I’m in the car. on is the parameter I’m passing in IFTTT.
int lightOn(String on)
Hi @danlee6992,
I’m glad you got it working!
David
