I2C LCD work for spark core?
sorry i don’t know ? support for spark core
128x64 LCD DS12864LCD
http://www.digole.com/index.php?searchstring=128x64%20cog%20uart
I couldn’t tell if that one uses the SSD1306 chip but the displays with the SSD1306 are pretty popular with Particle devices. I am using one myself, very easy to setup and use. I have this exact one, using I2C for comms. http://www.amazon.com/Diymall-Yellow-Serial-Arduino-Display/dp/B00O2LLT30/ref=sr_1_2?ie=UTF8&qid=1441018283&sr=8-2&keywords=ssd1306
@fangda01, all Digole “smart” displays support Serial/I2C/SPI communications and the library is easily used with both Core and Photon devices. I use these devices often. Have you looked at the color LCD unit?
http://digole.com/index.php?productID=1193
i have ssd1306 OLED 0.98 ’ and devolop code work but it small LCD i want to increase size same solution pixel
