I am trying to make a library for the MAX1361 ADC but when running the code below I get random output I know that the ADC is working because it shows up on an I2C scan. I am configuring the ADC to read from two of the four channels I think the problem is with how I am reading the values, I have attached an image of a diagram of how reading is suppose to happen any ideas what I'm doing wrong?
It looks like the wire format is MSB0 MSB1 LSB0 LSB1 but your code is assuming that the order is LSB0 MSB0 LSB1 MSB1. I think it should be something like this, unless I'm reading it incorrectly:
so I tried the changes to the code and I'm getting this error: expected primary-expression before '|' token and expected primary-expression before '=' token
(the error repeats with the second value)
There's no space between | and =. It's the bitwise or operator |=.
Also if you really need to mask off the lower 10 bits, and discard the high bits, you need to do it this way; you can't have it in the bitwise or code.
by the way the reason I'm masking the first six bits is that according to the datasheet
"The result is transmitted in 2 bytes. The 1st byte consists of a leading 1 followed by a 2-bit binary channel
address tag, a 12/10 bit flag (0 for the MAX1361/
MAX1362), 2 bits of 1s, the first 2 bits of the data result,
and the expected ACK from the master." and therefore I want to remove all but the last two bits
