HX711ADC library not compiling?
I added this library to my project as it depends on the weight, but every time I try to verify my code I keep getting this same error:
/src/automatedhookset.cpp:8:22: fatal error: HX711ADC.h: No such file or directory
 #include <HX711ADC.h>
compilation terminated.
make[1]: *** [../build/target/user/platform-10src/automatedhookset.o] Error 1
make: *** [user] Error 2
Could anyone explain to me what I am doing wrong?
Could you show a Screenshot of the IDE where we can see the files/libraries that have been included?
Can you try changing the statement to #include "HX711ADC.h"?
I keep having this issue, when you first import a library you sometimes need to change the include statement, but after that you can change it back and it still builds - no idea why.
sorry for the late response…
Yeah I tried that already and it still doesn’t work.
I see you are still using 0.4.8 firmware as target (see bottom right in your Web IDE)
That won’t help :wink:
Try updating to the current release version 0.6.1
Yeah I updated it earlier thinking that could possibly be the problem but I am still getting the same error. I’m at 0.6.1 now.
Can you post your full code (in a PM if you don’t want it seen by others)?
Here is my code as of now:
 * Include Libraries
#include "Ubidots.h"
 * Define Constants
#define DOUT  D0
#define CLK  D1
#define TOKEN "ubidots token #"  // My Ubidots TOKEN
Ubidots ubidots(TOKEN);
HX711ADC scale(DOUT, CLK);
float calibration_factor = -7050; //from sparkfun example (May be incorrect)
 * Main Functions
Serial.begin(115200);
scale.set_scale(calibration_factor);
scale.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
float weight = scale.getunits();
ubidots.add("weight", weight);  // Change for your variable name
ubidots.sendAll();
delay(5000);
After a minor change to your code scale.getunits(); to scale.get_units(); that builds for me.
Maybe just create a new project, copy/paste your code there, reimport the libs but remove the extra includes and see if that changes anything.
Thank you! As soon as I started the new project it compiled.
