using the following code
#include "HX711ADC/HX711ADC.h"
//#include "application.h"
// HX711.DOUT - pin #A1
// HX711.PD_SCK - pin #A0
set_scale(A1, A0); // parameter "gain" is ommited; the default value 128 is used by the library
Serial.println("HX711 Demo");
Serial.println("Before setting up the scale:");
Serial.print("read: \t\t");
Serial.println(scale.read()); // print a raw reading from the ADC
Serial.print("read average: \t\t");
Serial.println(scale.read_average(20)); // print the average of 20 readings from the ADC
Serial.print("get value: \t\t");
Serial.println(scale.get_value(5)); // print the average of 5 readings from the ADC minus the tare weight (not set yet)
Serial.print("get units: \t\t");
Serial.println(scale.get_units(5), 1); // print the average of 5 readings from the ADC minus tare weight (not set) divided
// by the SCALE parameter (not set yet)
scale.set_scale(2280.f); // this value is obtained by calibrating the scale with known weights; see the README for details
scale.tare(); // reset the scale to 0
Serial.println("After setting up the scale:");
Serial.println(scale.get_value(5)); // print the average of 5 readings from the ADC minus the tare weight, set with tare()
Serial.println(scale.get_units(5), 1); // print the average of 5 readings from the ADC minus tare weight, divided
// by the SCALE parameter set with set_scale
Serial.println("Readings:");
Serial.print("one reading:\t");
Serial.print(scale.get_units(), 1);
Serial.print("\t| average:\t");
Serial.println(scale.get_units(10), 1);
scale.power_down(); // put the ADC in sleep mode
delay(5000);
scale.power_up();
I am getting the following compile errors
This looks like an error in HX711ADC library. Would you like to create an issue on GitHub to let the author know?
CREATE ISSUE
HX711ADC/HX711ADC.h:12:3: error: 'byte' does not name a type
byte PD_SCK; // Power Down and Serial Clock Input Pin
CREATE ISSUE
HX711ADC/HX711ADC.h:13:3: error: 'byte' does not name a type
byte DOUT; // Serial Data Output Pin
I am not sure what this means. the code is an arduino example for weighing using a load cell and a HX711 ADC
