Hello!
I am running a slightly modified version of a firmware I have for the Electron, which works great posting ~5500 character http posts (the http posting is it’s own thread) using data collected from an ESP8266 which the Particle device talks to via UART. Unfortunately on the Boron, after enabling httpClient’s logging, I keep getting the error Error: Timeout while reading response with Status code: (usually no code at all, sometimes -1) followed by Error: Can't find HTTP response body and sometimes the device simply goes into SOS 1 (hard fault) after attempting the post, and sometimes the device loses cloud/cellular connection at random. I discovered that by reducing the message size down to ~400ish characters, the post actually will go through most of the time, although sometimes logging Error: Response body larger than buffer., and after a few of these successful tiny posts, this firmware will end up in SOS 1 (hard fault) as well. I am perplexed because if I have the boron print out the collected data instead of sending it, it seems 100% correct and no different that that of the electron, but for whatever reason the post fails on the boron. The HTTP response of the endpoint I am using to test this is also extremely short:
{"response": {
"metadata": {
"requestId": "xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxxxxx",
"status": "success",
"statusCode": "200"
"result": "Recieved"
This endpoint also sends the raw content of all requests to me as an email, and when the boron is sending the longer messages, they never come through (so it definitely isn’t just the response having issues).
I created this super-simplified snippet below to demonstrate this issue with just a boron, although I have noticed that in this version it does not fail catastrophically as often, my theory for that is that in the full code, I am also using @rickkas7 's serialBuffer library (thanks again for updating that!!) which creates a thread of it’s own, which I’m sure leads to big issues when my http posting thread gets hung up! I am not worried about that though, because I do this same thing on the electron, and when the httpclient thread doesn’t get hung up, there are no issues between it and the serialBuffer, so I suspect it wont be a problem on the boron either once this odd issue is resolved!
Here is the super-simplified code (it needs HttpClient library):
#include <HttpClient.h>
STARTUP(startupFunction());
SYSTEM_MODE(SEMI_AUTOMATIC);
SYSTEM_THREAD(ENABLED);
extern void startupFunction();
static char json_str[2048];
int timeAlive_s = 0;
int lastPost_s = 0;
HttpClient http;
http_header_t headers[] = {
{ "Accept" , "*/*"},
http_request_t request;
http_response_t response;
//Separate thread for HTTP requests so as not to block data collection
Thread *thread;
os_mutex_t mutex;
void startupFunction() {
System.enableFeature(FEATURE_RESET_INFO);
os_mutex_create(&mutex);
// SLAVE_SERIAL_CONSOLE.begin(57600); //initialize uart port
Serial.begin(115200); //initialize debug port
// SLAVE_SERIAL_CONSOLE.setup();
os_mutex_lock(mutex);
thread = new Thread("httpSendData", http_send_data);
Serial.println("Calling Cellular.connect.");
Cellular.connect();
while (!Cellular.ready()) {
Serial.print(".");
delay(333);
Serial.println("!");
delay(100);
Serial.print("Calling Particle.connect");
Particle.connect();
while (!Particle.connected()) {
Serial.print(".");
delay(333);
memset(json_str, 'A', 2048); //Fill with 'A's to simulate data
Serial.println("Waiting");
uint32_t loopTime_ms = millis();
if ((uint32_t)timeAlive_s*1000 <= loopTime_ms) {
timeAlive_s++;
Serial.print(".");
if(timeAlive_s >= 30 && (timeAlive_s - 30) >= lastPost_s){
Serial.println("Posting");
os_mutex_unlock(mutex);
lastPost_s = timeAlive_s;
Particle.process();
void http_send_data(){
while(true){
request.hostname = "HOSTNAME_HERE"; //In my case for testing, I am just using an endpoint which sends the raw request to me as an email
request.port = 80;
request.path = "PATH_HERE";
request.body = json_str;
http.post(request, response, headers);
Any help would be immensely appreciated, I am quite excited to begin deploying Borons for new projects as well as replacing electrons in old ones, but this seems to be the last hangup blocking me!
