How to use Programmer shield + GPS Shield to debug firmware
Hello,
I just received my new asset tracker. I would like to debug the firmware locally and I see I need programmer shield but if I use programmer shield I can’t use GP shield. Is there way to use a programmer shield or other JTAG/SWD device that I can use with Electron when it is connected with GPS shield ?
The other question is, is there a tutorial to setup the firmware project with STM32 System Workbench IDE ?
Sri
This FAQ can help you get set up with Eclipse for source-level debugging firmware:
https://docs.particle.io/faq/particle-tools/eclipse-debug/
You’ll want to use a USB mini ST-LINK/V2 compatible SWD debugging stick. I got mine for US$15 from Amazon but you can get them even cheaper on Amazon or eBay now.
Thanks rickkas7. But will the debugging stick work with out breadboard ? I am not sure if I can connect electron board to the breadboard while its connected to the shield.
