How to setup the third party SIM
I am trying to setup the third party SIM to use Electron.
But I can not find the method to enter the UserID and Password for cellular proveider APN.
Can I enter the UserID and Password in “You have a non-Particle SIM card” page?
https://setup.particle.io/
If you have already configured to work with Electron Particle SIM then just flash program with the following configuration:
// EXAMPLE - an AT&T APN with no username or password in AUTOMATIC mode
#include "cellular_hal.h"
STARTUP(cellular_credentials_set("broadband", "", "", NULL));
  // your setup code
  // your loop code
For more information see the following link. https://docs.particle.io/reference/firmware/electron/#setcredentials-
I understand to use the third party SIM when it is necessary to download the firmware that APN information was set at, and to write in it at a device, is it right?
Sort of.
You need the code outlined by @developer_bt in each of your applications - not only once
Thanks.
I tried this code.
STARTUP(cellular_credentials_set("APN", "", "", NULL));
My Electron goes flashing green forever.
I thought it must have a USERID and PASSWORD for APN.
So I tried this code.
STARTUP(cellular_credentials_set("APN", "USERID ", "PASSWORD ", NULL));
SYSTEM_MODE(MANUAL);
int DoCommand( const char* command )
     int ret = Cellular.command(cb, resp, 256, buf);
    Cellular.on();
    DoCommand("AT+CGATT?");           // reset
    DoCommand("AT+UPSDA=0,0");        // reset
    DoCommand("AT+CMEE=2");           // Set the verbose error result codes
    DoCommand("AT+CREG=1");           // Enable the network registration URC.
    DoCommand("AT+UPSND=0,8");        // PSD profile status: if the profile is active the return value is 1, 0 otherwise
    DoCommand("AT+UPSD=0,0");         // 0 Proticol IPv4
    DoCommand("AT+UPSD=0,1,\"APN\"");         // 1 APN
    DoCommand("AT+UPSD=0,2,\"USERID\"");      // 2 User Name
    DoCommand("AT+UPSD=0,3,\"PASSWORD\"");    // 3 Password
    DoCommand("AT+UPSD=0,6,2");               // 6 authentication 2=CHAP
    DoCommand("AT+UPSD=0,7,\"0.0.0.0\"");     // 7 IP Address 0.0.0.0 = dynamic
    if( DoCommand("AT+UPSDA=0,3") != RESP_ERROR )   // activate
        WaitURC("+UUSPDA:");
    for( int i = 0; i < 60; i ++ )
        int ret = DoCommand("AT+UPSND=0,0"); // IP address: dynamic IP address assigned
                                             //during PDP context activation;
        if(ret == RESP_OK ) break;
            delay(1000);
Worked well.
But after a few days, I got following error when using the compile and download.
Error: 500. Please try again later. If the issue persists, please report to hello@particle.io.
I thought that the cause of this error was caused by a fact that the registration to a cloud of SIM was not completed.
But the setup page does not have Field inputting a USERID and PASSWORD.
So I do not use the web site to register the third party SIM.
Do you have tasted whether works with Particle SIM?
Whether the card is factory-sized to nano or later you have the cut?
I had also a problem with incorrectly cut card resulting in a flashing green and then enters into listening mode.
Yes I have tested,my Electron is working well with Particle SIM.
The size in third party SIM is nano,I haven’t cut.
Would you mind posting your WaitURC() function
The function sends a CRLF, and waits for a response.
int WaitURC( char* waitText )
    char *buf = "\r\n";
    for(int i = 0; i < 10; i ++)
        if ( ret == RESP_OK )
            if( strncmp(resp, waitText, strlen(waitText)) == 0)
                break;
        delay(1000);
    return(ret);
Thanks.
