hey all
for posterity, here’s how to install an extension from a .vsix file:
- from VSCode’s main menu, select “Extensions”
- click to open the three-dot menu at the top of the middle panel (see screenshot above)
- select “Install from VSIX…” and follow the prompts
after installing, you may be prompted to reload but after that your new extension should be available for use.
cheers!
-m
