Can someone help to include this arduino library to the spark library? Below is the .cpp then at the bottom half there is the code for the .h Lastly the keywords at the very bottom. Thank you so much in advance!
BitVoicer.cpp - Implements serial communication with the BitVoicer.
Created by BitSophia Software Ltd., Dcember 03, 2012.
Realeased into public domain.
#include "Arduino.h"
#include "wiring_private.h"
#include "BitVoicer11.h"
//Class constructor
//Receives an integer indicating the serial port to be used
BitVoicerSerial::BitVoicerSerial()
//Sets all public variables to NULL, engine status to stopped
//and the analog voltage reference
byteData = NULL;
charData = NULL;
intData = NULL;
strData= "";
cmdData = NULL;
engineRunning = false;
_bvAnalogReference = BV_DEFAULT;
//Retrieves data from serial buffer and stores it in the
//correct public variable.
//Returns the received data type (byte) or ZERO if corrupted
//data is received or if no data is available
byte BitVoicerSerial::getData()
//Creates internal variables
byte dataType = 0;
byte dataLength = 0;
int bytesAvailable = 0;
//Gives Arduino a time to finish receiving serial
//data. This delay can be reduced at faster reading
//speeds or when receiving small datagrams
if (Serial.available() > 0)
delay(100);
bytesAvailable = Serial.available();
//If the received data is smaller than the minimum datagram
//size or the first byte is not the start of transmission
//mark, NO operation is performed
if (bytesAvailable >= 5 && Serial.peek() == 1)
//Reads the start of transmission mark
Serial.read();
//Reads and stores the data type
dataType = Serial.read();
//Reads and stores the data length
dataLength = Serial.read();
//Reads and stores the data for the expected length
for (int i = 0; i < dataLength; i++)
_data[i] = Serial.read();
//If the end os transmission mark is not found,
//returns data type to zero. All data will be
//disregarded
if (Serial.read() != 4)
dataType = 0;
else
//Sets the data in the temporary buffer to the correct
//public variable
setData(dataType, dataLength);
//Returns the retrived data type
return dataType;
//Clears the serial buffer until the start of transmission
//mark is found and there is 5 bytes available
for (int i = 0; i < bytesAvailable; i++)
if (Serial.peek() == 1 && Serial.available() < 5)
Serial.read();
else if (Serial.peek() == 1 && Serial.available() >= 5)
break;
else
Serial.read();
//returns ZERO because:
//- No data was available or
//- Corrupted data has been received or
//- The received datagram is invalid
return dataType;
//Retrieves data from _data and sets the
//respective public variables
void BitVoicerSerial::setData(byte dataType, int dataLength)
//Validates passed variables
if (dataType == 0 || dataLength <= 0)
byteData = NULL;
charData = NULL;
intData = NULL;
strData= "";
cmdData = NULL;
return;
//Selects the correct procedure for each data type,
//retrieves the data from internal buffer and
//sets it in the correct variable
switch (dataType)
//Case byte
case BV_BYTE:
//Sets byte public variable to the first byte in the
//internal buffer
byteData = _data[0];
charData = NULL;
intData = NULL;
strData= "";
cmdData = NULL;
break;
//Case char
case BV_CHAR:
byteData = NULL;
//Sets char public variable to the converted first byte
//in the internal buffer
charData = char(_data[0]);
intData = NULL;
strData= "";
cmdData = NULL;
break;
//Case int
case BV_INT:
byteData = NULL;
charData = NULL;
//Converts 2 bytes from internal buffer into
//Arduino 16 bits int and sets int public variable
intData = _data[0] | (_data[1] << 8);
strData= "";
cmdData = NULL;
break;
//Case String
case BV_STR:
byteData = NULL;
charData = NULL;
intData = NULL;
strData = "";
//Loops the internal buffer and concatenates the
//data into the string public variable
strData += char(_data[i]);
cmdData = NULL;
break;
//Case command
case BV_COMMAND:
byteData = NULL;
charData = NULL;
intData = NULL;
strData = "";
//Sets command public variable to the first byte in the
//internal buffer
cmdData = _data[0];
break;
//Case status
case BV_STATUS:
//Checks the received status data and sets the engine
//status public variable
engineRunning = _data[0];
//Signals the BitVoicer's recognition engine to start or stop
//processing audio streams
void BitVoicerSerial::startStopListening()
//The start/stop signal
byte signal[] = {255, 255, 255, 255, 0, 0, 0, 0};
//Sends the signal to the serial port
for (int i = 0; i < 8; i++)
Serial.write(signal[i]);
//Fast reads the analog input port and sends the result
//to BitVoicer. It receives a delay value that can be used
//to equalize the stream rate
void BitVoicerSerial::processAudio(unsigned int wait)
//Delays the execution for the passed time (microseconds)
if (wait > 0)
delayMicroseconds(wait);
//Starts the ADC conversion
sbi(ADCSRA, ADSC);
//Whaits for the ADC convertion to finish
while (bit_is_set(ADCSRA, ADSC));
//Sends the 8 bit result to BitVoicer
Serial.write(ADCH);
//Changes the analog voltage reference on the board
//Do NOT use arduino constants when calling this function!!!
//You may end up burning your board
void BitVoicerSerial::setAnalogReference(uint8_t mode)
_bvAnalogReference = mode;
//Sets up the microcontroller to perform faster analog
//conversions on the specified pin
void BitVoicerSerial::setAudioInput(uint8_t pin)
//Check if the pin value is in the accepted range
if (pin > 5)
return;
//Sets the analog reference (high two bits of ADMUX),
//selects the pin (low 4 bits) and sets ADLAR to left-adjust
//the reslt (writes 1 to ADLAR)
ADMUX = ((_bvAnalogReference << 5) | (pin & 0x07));
//Sets the ADC clock to a faster clock
//Since an 8 bit resolution is sufficient, it does not affect
//the ADC accuracy
sbi(ADCSRA, ADPS2);
sbi(ADCSRA, ADPS1);
cbi(ADCSRA, ADPS0);
//Returns the ADC and ADMUX to their original settings
void BitVoicerSerial::undoAudioInput()
ADMUX = 0x00;
sbi(ADCSRA, ADPS2);
sbi(ADCSRA, ADPS1);
sbi(ADCSRA, ADPS0);
//BitVoicerSerial.sendToBV()
//Aceita byte, char, int, string
//Wraps one byte in the BitVoicer Protocol and
//sends it to BitVoicer
void BitVoicerSerial::sendToBV(uint8_t b)
Serial.write(1);
Serial.write(BV_BYTE);
Serial.write(1);
Serial.write(b);
Serial.write(4);
//Wraps one char in the BitVoicer Protocol and
void BitVoicerSerial::sendToBV(char c)
Serial.write(1);
Serial.write(BV_CHAR);
Serial.write(1);
Serial.write((byte)c);
Serial.write(4);
//Wraps one int in the BitVoicer Protocol and
void BitVoicerSerial::sendToBV(int n)
Serial.write(1);
Serial.write(BV_INT);
Serial.write(2);
Serial.write((byte)(n & 0XFF));
Serial.write((byte)((n >> 8) & 0XFF));
Serial.write(4);
//Wraps a String object in the BitVoicer Protocol and
void BitVoicerSerial::sendToBV(String s)
Serial.write(1);
Serial.write(BV_STR);
Serial.write(s.length());
for (int i = 0; i < s.length(); i++)
Serial.write((byte)s.charAt(i));
Serial.write(4);
BitVoicer.h - Implements serial communication with the BitVoicer.
Created by BitSophia Software Ltd., December 03, 2012.
#ifndef BitVoicer11_h
#define BitVoicer11_h
//Internal BitVoicerSerial buffer
#define BUFFER_SIZE = 64;
//Analog reference constants
#define BV_DEFAULT 3
#define BV_EXTERNAL 1
//Defines BitVoicer constants
#define BV_UNDEFINED 0
#define BV_CHAR 1
#define BV_INT 2
#define BV_BYTE 3
#define BV_STR 4
#define BV_COMMAND 254
#define BV_STATUS 255
#define BV_STARTSAMPLING 1
#define BV_STOPSAMPLING 0
#define BV_ENGINESTOPPED 0
#define BV_ENGINERUNNING 1
//Defines all elements of the class
class BitVoicerSerial
public:
//Class constructor
BitVoicerSerial();
//Method that retrieves data from serial port
byte getData();
//Method that sends a start/stop listening signal to BitVoicer
void startStopListening();
//BitVoicer's audio processing method
void processAudio(unsigned int wait);
//Method that sets up the audio input
void setAudioInput(uint8_t pin);
//Sets the analog voltage reference
void setAnalogReference(uint8_t mode);
//Method that sets Arduino back to its original input settings
void undoAudioInput();
//Sends a byte to BitVoicer
void sendToBV(uint8_t b);
//Sends a char to BitVoicer
void sendToBV(char c);
//Sends a int to BitVoicer
void sendToBV(int n);
//Sends a String object to BitVoicer
void sendToBV(String s);
//Stores byte data
byte byteData;
//Stores char data
char charData;
//Stores int data
int intData;
//Stores string data
String strData;
//Stores command data
byte cmdData;
//Stores engine status
boolean engineRunning;
private:
//Stores temporary data read from the serial port
byte _data[64];
//Sets the public variables with the correct data
//from last read
void setData(byte dataType, int dataLength);
//Stores the analog voltage reference
uint8_t _bvAnalogReference;
#endif
BitVoicerSerial KEYWORD1
startStopListening KEYWORD2
processAudio KEYWORD2
setAnalogReference KEYWORD2
setAudioInput KEYWORD2
undoAudioInput KEYWORD2
sendToBV KEYWORD2
getData KEYWORD2
byteData KEYWORD2
charData KEYWORD2
intData KEYWORD2
strData KEYWORD2
cmdData KEYWORD2
engineRunning KEYWORD2
BUFFER_SIZE LITERAL1
BV_UNDEFINED LITERAL1
BV_CHAR LITERAL1
BV_INT LITERAL1
BV_BYTE LITERAL1
BV_STR LITERAL1
BV_COMMAND LITERAL1
BV_STATUS LITERAL1
BV_STARTSAMPLING LITERAL1
BV_STOPSAMPLING LITERAL1
BV_ENGINESTOPPED LITERAL1
BV_ENGINERUNNING LITERAL1
BV_DEFAULT LITERAL1
BV_EXTERNAL LITERAL1
