Hi
Can anybody help me to port this for the spark? It is for lightwaverf home automation but will not compile for the due. I have no idea how to even start doing this hence this post. For now I am using a custom yabbas to receive and transmit lightwaverf and interfacing to a Sainsmart due for network connectivity, it works but is not ideal, the yabbas cannot keep up with the signals! This is why I ordered a spark, I was hoping it would cut out loads of peripherals but it is no real use if I can’t port this library.
// LwRx.cpp
// LightwaveRF 434MHz receiver interface for Arduino
// Author: Bob Tidey (robert@tideys.net)
#include <LwRx.h>
//define EEPROMaddr to location to store pair data or -1 to skip EEPROM
//First byte is pair count followed by 8 byte pair addresses (device,dummy,5*addr,room)
#define EEPROMaddr -1
static const byte rx_nibble[] = {0xF6,0xEE,0xED,0xEB,0xDE,0xDD,0xDB,0xBE,0xBD,0xBB,0xB7,0x7E,0x7D,0x7B,0x77,0x6F};
static const byte rx_cmd_off = 0xF6; // raw 0
static const byte rx_cmd_on = 0xEE; // raw 1
static const byte rx_cmd_mood = 0xED; // raw 2
static const byte rx_par0_alloff = 0x7D; // param 192-255 all off (12 in msb)
static const byte rx_dev_15 = 0x6F; // device 15
static int rx_pin = 2;
static const byte rx_msglen = 10; // expected length of rx message
//Receive mode constants and variables
static byte rx_msg[rx_msglen]; // raw message received
static byte rx_buf[rx_msglen]; // message buffer during reception
static unsigned long rx_prev; // time of previous interrupt in microseconds
static boolean rx_msgcomplete = false; //set high when message available
static boolean rx_translate = true; // Set false to get raw data
static byte rx_state = 0;
static const byte rx_state_idle = 0;
static const byte rx_state_msgstartfound = 1;
static const byte rx_state_bytestartfound = 2;
static const byte rx_state_getbyte = 3;
static byte rx_num_bits = 0; // number of bits in the current byte
static byte rx_num_bytes = 0; // number of bytes received
//Pairing data
static byte rx_paircount = 0;
static byte rx_pairs[rx_maxpairs][8];
static byte rx_pairtimeout = 0; // 100msec units
//set false to responds to all messages if no pairs set up
static boolean rx_pairEnforce = false;
//set false to use Address, Room and Device in pairs, true just the Address part
static boolean rx_pairBaseOnly = false;
// Repeat filters
static byte rx_repeats = 2; //msg must be repeated at least this number of times
static byte rx_repeatcount = 0;
static byte rx_timeout = 20; //reset repeat window after this in 100mSecs
static unsigned long rx_prevpkttime = 0; //last packet time in milliseconds
static unsigned long rx_pairstarttime = 0; //last msg time in milliseconds
// Gather stats for pulse widths (ave is x 16)
static const unsigned int lwrx_statsdflt[rx_stat_count] = {5000,0,5000,20000,0,2500,4000,0,500};
static unsigned int lwrx_stats[rx_stat_count];
static boolean lwrx_stats_enable = true;
Pin change interrupt routine that identifies 1 and 0 LightwaveRF bits
and constructs a message when a valid packet of data is received.
void rx_process_bits() {
byte event = digitalRead(rx_pin); // start setting event to the current value
unsigned long curr = micros(); // the current time in microseconds
unsigned int dur = (curr-rx_prev);
rx_prev = curr;
//set event based on input and duration of previous pulse
if(dur < 120) { //120 very short
} else if(dur < 500) { // normal short pulse
event +=2;
} else if(dur < 2000) { // normal long pulse
event +=4;
} else if(dur > 5000){ // gap between messages
event +=6;
} else { //2000 > 5000
event = 8; //illegal gap
//state machine transitions
switch(rx_state) {
case rx_state_idle:
switch(event) {
case 7: //1 after a message gap
rx_state = rx_state_msgstartfound;
break;
break;
case rx_state_msgstartfound:
switch(event) {
case 2: //0 160->500
//nothing to do wait for next positive edge
break;
case 3: //1 160->500
rx_num_bytes = 0;
rx_state = rx_state_bytestartfound;
break;
default:
//not good start again
rx_state = rx_state_idle;
break;
break;
case rx_state_bytestartfound:
switch(event) {
break;
rx_state = rx_state_getbyte;
rx_num_bits = 0;
break;
case 5: //0 500->1500
// Starts with 0 so put this into byte
rx_num_bits = 1;
rx_buf[rx_num_bytes] = 0;
break;
default:
break;
break;
case rx_state_getbyte:
switch(event) {
//nothing to do wait for next positive edge but do stats
if(lwrx_stats_enable) {
lwrx_stats[rx_stat_high_max] = max(lwrx_stats[rx_stat_high_max], dur);
lwrx_stats[rx_stat_high_min] = min(lwrx_stats[rx_stat_high_min], dur);
lwrx_stats[rx_stat_high_ave] = lwrx_stats[rx_stat_high_ave] - (lwrx_stats[rx_stat_high_ave] >> 4) + dur;
break;
// a single 1
rx_buf[rx_num_bytes] = rx_buf[rx_num_bytes] << 1 | 1;
rx_num_bits++;
lwrx_stats[rx_stat_low1_max] = max(lwrx_stats[rx_stat_low1_max], dur);
lwrx_stats[rx_stat_low1_min] = min(lwrx_stats[rx_stat_low1_min], dur);
lwrx_stats[rx_stat_low1_ave] = lwrx_stats[rx_stat_low1_ave] - (lwrx_stats[rx_stat_low1_ave] >> 4) + dur;
break;
case 5: //1 500->1500
// a 1 followed by a 0
rx_buf[rx_num_bytes] = rx_buf[rx_num_bytes] << 2 | 2;
rx_num_bits++;
rx_num_bits++;
lwrx_stats[rx_stat_low0_max] = max(lwrx_stats[rx_stat_low0_max], dur);
lwrx_stats[rx_stat_low0_min] = min(lwrx_stats[rx_stat_low0_min], dur);
lwrx_stats[rx_stat_low0_ave] = lwrx_stats[rx_stat_low0_ave] - (lwrx_stats[rx_stat_low0_ave] >> 4) + dur;
break;
default:
break;
if(rx_num_bits >= 8) {
rx_num_bytes++;
rx_num_bits = 0;
if(rx_num_bytes >= rx_msglen) {
unsigned long currMillis = millis();
if(rx_repeats > 0) {
if((currMillis - rx_prevpkttime) / 100 > rx_timeout) {
rx_repeatcount = 1;
} else {
//Test message same as last one
int i = rx_msglen;
do {
i--;
while((i >= 0) && (rx_msg[i] == rx_buf[i]));
if(i < 0) {
rx_repeatcount++;
} else {
rx_repeatcount = 1;
} else {
rx_repeatcount = 0;
rx_prevpkttime = currMillis;
//If last message hasn't been read it gets overwritten
memcpy(rx_msg, rx_buf, rx_msglen);
if(rx_repeats == 0 || rx_repeatcount == rx_repeats) {
if(rx_pairtimeout != 0) {
if((currMillis - rx_pairstarttime) / 100 <= rx_pairtimeout) {
if(rx_msg[3] == rx_cmd_on) {
rx_addpairfrommsg();
} else if(rx_msg[3] == rx_cmd_off) {
rx_removePair(&rx_msg[2]);
if(rx_reportMessage()) {
rx_msgcomplete = true;
rx_pairtimeout = 0;
// And cycle round for next one
} else {
break;
Test if a message has arrived
boolean lwrx_message() {
return (rx_msgcomplete);
Set translate mode
void lwrx_settranslate(boolean rxtranslate) {
rx_translate = rxtranslate;
Transfer a message to user buffer
boolean lwrx_getmessage(byte *buf, byte len) {
boolean ret = true;
int j=0,k=0;
if(rx_msgcomplete && len <= rx_msglen) {
for(byte i=0; ret && i < rx_msglen; i++) {
if(rx_translate || (len != rx_msglen)) {
j = rx_findNibble(rx_msg[i]);
if(j<0) ret = false;
} else {
j = rx_msg[i];
switch(len) {
case 4:
if(i==9) buf[2]=j;
if(i==2) buf[3]=j;
case 2:
if(i==3) buf[0]=j;
if(i==0) buf[1]=j<<4;
if(i==1) buf[1]+=j;
break;
case 10:
buf[i]=j;
break;
rx_msgcomplete= false;
} else {
ret = false;
return ret;
Return time in milliseconds since last packet received
unsigned long lwrx_packetinterval() {
return millis() - rx_prevpkttime;
Set up repeat filtering of received messages
void lwrx_setfilter(byte repeats, byte timeout) {
rx_repeats = repeats;
rx_timeout = timeout;
Add a pair to filter received messages
pairdata is device,dummy,5*addr,room
pairdata is held in translated form to make comparisons quicker
byte lwrx_addpair(byte* pairdata) {
if(rx_paircount < rx_maxpairs) {
for(byte i=0; i<8; i++) {
rx_pairs[rx_paircount][i] = rx_nibble[pairdata[i]];
rx_paircommit();
return rx_paircount;
Make a pair from next message successfully received
extern void lwrx_makepair(byte timeout) {
rx_pairtimeout = timeout;
rx_pairstarttime = millis();
Get pair data (translated back to nibble form
extern byte lwrx_getpair(byte* pairdata, byte pairnumber) {
if(pairnumber < rx_paircount) {
int j;
j = rx_findNibble(rx_pairs[pairnumber][i]);
if(j>=0) pairdata[i] = j;
Clear all pairing
extern void lwrx_clearpairing() {
rx_paircount = 0;
if(EEPROMaddr >= 0) {
EEPROM.write(EEPROMaddr, 0);
Return stats on high and low pulses
boolean lwrx_getstats(unsigned int *stats) {
memcpy(stats, lwrx_stats, 2 * rx_stat_count);
return true;
} else {
return false;
Set stats mode
void lwrx_setstatsenable(boolean rx_stats_enable) {
lwrx_stats_enable = rx_stats_enable;
if(!lwrx_stats_enable) {
//clear down stats when disabling
memcpy(lwrx_stats, lwrx_statsdflt, sizeof(lwrx_statsdflt));
Set pairs behaviour
void lwrx_setPairMode(boolean pairEnforce, boolean pairBaseOnly) {
rx_pairEnforce = pairEnforce;
rx_pairBaseOnly = pairBaseOnly;
Set things up to receive LightWaveRF 434Mhz messages
pin must be 2 or 3 to trigger interrupts
void lwrx_setup(int pin) {
restoreEEPROMPairing();
rx_pin = (pin == 3) ? 3 : 2;
pinMode(rx_pin,INPUT);
attachInterrupt(rx_pin - 2, rx_process_bits, CHANGE);
Check a message to see if it should be reported under pairing / mood / all off rules
returns -1 if none found
boolean rx_reportMessage() {
if(rx_pairEnforce && rx_paircount == 0) {
return false;
} else {
boolean allDevices;
// True if mood to device 15 or Off cmd with Allof paramater
allDevices = ((rx_msg[3] == rx_cmd_mood && rx_msg[2] == rx_dev_15) ||
(rx_msg[3] == rx_cmd_off && rx_msg[0] == rx_par0_alloff));
return (rx_checkPairs(&rx_msg[2], allDevices) != -1);
Find nibble from byte
int rx_findNibble(byte data) {
int i = 15;
do {
if(rx_nibble[i] == data) break;
i--;
} while (i >= 0);
return i;
add pair from message buffer
void rx_addpairfrommsg() {
memcpy(rx_pairs[rx_paircount], &rx_msg[2], 8);
rx_paircommit();
check and commit pair
void rx_paircommit() {
if(rx_paircount == 0 || rx_checkPairs(rx_pairs[rx_paircount], false) < 0) {
EEPROM.write(EEPROMaddr + 1 + 8 * rx_paircount + i, rx_pairs[rx_paircount][i]);
rx_paircount++;
EEPROM.write(EEPROMaddr, rx_paircount);
Check to see if message matches one of the pairs
if mode is pairBase only then ignore device and room
if allDevices is true then ignore the device number
Returns matching pair number, -1 if not found, -2 if no pairs defined
int rx_checkPairs(byte *buf, boolean allDevices ) {
if(rx_paircount ==0) {
return -2;
} else {
int pair= rx_paircount;
int j = -1;
int jstart,jend;
if(rx_pairBaseOnly) {
// skip room(8) and dev/cmd (0,1)
jstart = 7;
jend = 2;
} else {
//include room in comparison
jstart = 8;
//skip device comparison if allDevices true
jend = (allDevices) ? 2 : 0;
while (pair>0 && j<0) {
pair--;
j = jstart;
while(j>jend){
j--;
if(j != 1) {
if(rx_pairs[pair][j] != buf[j]) {
j = -1;
return (j >= 0) ? pair : -1;
Remove an existing pair matching the buffer
void rx_removePair(byte *buf) {
int pair = rx_checkPairs(buf, false);
if(pair >= 0) {
while (pair < rx_paircount - 1) {
for(byte j=0; j<8;j++) {
rx_pairs[pair][j] = rx_pairs[pair+1][j];
EEPROM.write(EEPROMaddr + 1 + 8 * pair + j, rx_pairs[pair][j]);
pair++;
rx_paircount--;
Retrieve and set up pairing data from EEPROM if used
void restoreEEPROMPairing() {
rx_paircount = EEPROM.read(EEPROMaddr);
if(rx_paircount > rx_maxpairs) {
rx_paircount = 0;
} else {
for( byte i=0; i < rx_paircount; i++) {
for(byte j=0; j<8; j++) {
rx_pairs[i][j] = EEPROM.read(EEPROMaddr + 1 + 8 * i + j);
// LwRx.h
// LightwaveRF 434MHz receiver for Arduino
#include <Arduino.h>
#include <../EEPROM/EEPROM.h>
#define rx_stat_high_ave 0
#define rx_stat_high_max 1
#define rx_stat_high_min 2
#define rx_stat_low0_ave 3
#define rx_stat_low0_max 4
#define rx_stat_low0_min 5
#define rx_stat_low1_ave 6
#define rx_stat_low1_max 7
#define rx_stat_low1_min 8
#define rx_stat_count 9
//sets maximum number of pairings which can be held
#define rx_maxpairs 10
//Setup must be called once, set up pin used to receive data
extern void lwrx_setup(int pin);
//Set translate to determine whether translating from nibbles to bytes in message
//Translate off only applies to 10char message returns
extern void lwrx_settranslate(boolean translate);
// Check to see whether message available
extern boolean lwrx_message();
//Get a message, len controls format (2 cmd+param, 4 cmd+param+room+device),10 full message
extern boolean lwrx_getmessage(byte* buf, byte len);
//Setup repeat filter
extern void lwrx_setfilter(byte repeats, byte timeout);
//Add pair, if no pairing set then all messages are received, returns number of pairs
extern byte lwrx_addpair(byte* pairdata);
// Get pair data into buffer for the pairnumber. Returns current paircount
// Use pairnumber 255 to just get current paircount
extern byte lwrx_getpair(byte* pairdata, byte pairnumber);
//Make a pair from next message received within timeout 100mSec
//This call returns immediately whilst message checking continues
extern void lwrx_makepair(byte timeout);
//Set pair mode controls
extern void lwrx_setPairMode(boolean pairEnforce, boolean pairBaseOnly);
//Returns time from last packet received in msec
// Can be used to determine if Rx may be still receiving repeats
extern unsigned long lwrx_packetinterval();
extern void lwrx_clearpairing();
//Return stats on pulse timings
extern boolean lwrx_getstats(unsigned int* stats);
//Enable collection of stats on pulse timings
extern void lwrx_setstatsenable(boolean rx_stats_enable);
//internal support functions
boolean rx_reportMessage();
int rx_findNibble(byte data);
void rx_addpairfrommsg();
void rx_paircommit();
void rx_removePair(byte *buf);
int rx_checkPairs(byte *buf, boolean allDevices);
void restoreEEPROMPairing();
// LwTx.cpp
// LightwaveRF 434MHz tx interface for Arduino
#include <LwTx.h>
//define EEPROMaddr to location to store message addr or -1 to skip EEPROM
#define EEPROMaddr 0
static byte tx_nibble[] = {0xF6,0xEE,0xED,0xEB,0xDE,0xDD,0xDB,0xBE,0xBD,0xBB,0xB7,0x7E,0x7D,0x7B,0x77,0x6F};
static int tx_pin = 3;
static const byte tx_msglen = 10; // the expected length of the message
//Transmit mode constants and variables
static byte tx_repeats = 12; // Number of repeats of message sent
static byte txon = 1;
static byte txoff = 0;
static boolean tx_msg_active = false; //set true to activate message sending
static boolean tx_translate = true; // Set false to send raw data
static byte tx_buf[tx_msglen]; // the message buffer during reception
static byte tx_repeat = 0; //counter for repeats
static byte tx_state = 0;
static byte tx_toggle_count = 3;
static unsigned int tx_gap_repeat = 0;
// These set the pulse durations in ticks
static byte tx_low_count = 7; // total number of ticks in a low (980 uSec)
static byte tx_high_count = 4; // total number of ticks in a high (560 uSec)
static byte tx_trail_count = 2; //tick count to set line low (280 uSec)
// Use with low repeat counts
static byte tx_gap_count = 72; // Inter-message gap count (10.8 msec)
//Gap multiplier byte is used to multiply gap if longer periods are needed for experimentation
//If gap is 255 (35msec) then this to give a max of 9 seconds
//Used with low repeat counts to find if device times out
static byte tx_gap_multiplier = 0; //Gap extension byte
static const byte tx_state_idle = 0;
static const byte tx_state_msgstart = 1;
static const byte tx_state_bytestart = 2;
static const byte tx_state_sendbyte = 3;
static const byte tx_state_msgend = 4;
static const byte tx_state_gapstart = 5;
static const byte tx_state_gapend = 6;
static byte tx_bit_mask = 0; // bit mask in current byte
static byte tx_num_bytes = 0; // number of bytes sent
Set translate mode
void lwtx_settranslate(boolean txtranslate)
tx_translate = txtranslate;
ISR(TIMER2_COMPA_vect){
//Set low after toggle count interrupts
tx_toggle_count--;
if (tx_toggle_count == tx_trail_count) {
digitalWrite(tx_pin, txoff);
} else if (tx_toggle_count == 0) {
tx_toggle_count = tx_high_count; //default high pulse duration
switch (tx_state) {
case tx_state_idle:
if(tx_msg_active) {
tx_repeat = 0;
tx_state = tx_state_msgstart;
break;
case tx_state_msgstart:
digitalWrite(tx_pin, txon);
tx_num_bytes = 0;
tx_state = tx_state_bytestart;
break;
case tx_state_bytestart:
tx_bit_mask = 0x80;
tx_state = tx_state_sendbyte;
break;
case tx_state_sendbyte:
if(tx_buf[tx_num_bytes] & tx_bit_mask) {
} else {
// toggle count for the 0 pulse
tx_toggle_count = tx_low_count;
tx_bit_mask >>=1;
if(tx_bit_mask == 0) {
tx_num_bytes++;
if(tx_num_bytes >= tx_msglen) {
tx_state = tx_state_msgend;
} else {
break;
case tx_state_msgend:
tx_state = tx_state_gapstart;
tx_gap_repeat = tx_gap_multiplier;
break;
case tx_state_gapstart:
tx_toggle_count = tx_gap_count;
if (tx_gap_repeat == 0) {
tx_state = tx_state_gapend;
} else {
tx_gap_repeat--;
break;
case tx_state_gapend:
tx_repeat++;
if(tx_repeat >= tx_repeats) {
//disable timer 2 interrupt
TIMSK2 &= ~(1 << OCIE2A);
tx_state = tx_state_idle;
} else {
break;
Check for send free
boolean lwtx_free() {
return !tx_msg_active;
Send a LightwaveRF message (10 nibbles in bytes)
void lwtx_send(byte *msg) {
if (tx_translate) {
for (byte i=0; i < tx_msglen; i++) {
tx_buf[i] = tx_nibble[msg[i] & 0xF];
} else {
memcpy(tx_buf, msg, tx_msglen);
//enable timer 2 interrupts
TIMSK2 |= (1 << OCIE2A);
tx_msg_active = true;
Set 5 char address for future messages
void lwtx_setaddr(byte *addr) {
for (byte i=0; i < 5; i++) {
tx_buf[i+4] = tx_nibble[addr[i] & 0xF];
EEPROM.write(EEPROMaddr + i, tx_buf[i+4]);
void lwtx_cmd(byte command, byte parameter, byte room, byte device) {
tx_buf[0] = tx_nibble[parameter >> 4];
tx_buf[1] = tx_nibble[parameter & 0xF];
tx_buf[2] = tx_nibble[device & 0xF];
tx_buf[3] = tx_nibble[command & 0xF];
tx_buf[9] = tx_nibble[room & 0xF];
Set things up to transmit LightWaveRF 434Mhz messages
void lwtx_setup(int pin, byte repeats, byte invert, int uSec) {
for(int i=0; i<5; i++) {
tx_buf[i+4] = EEPROM.read(EEPROMaddr+i);
if(pin !=0) {
tx_pin = pin;
if(repeats > 0 && repeats < 40) {
tx_repeats = repeats;
if(invert != 0) {
txon = 0;
txoff = 1;
} else {
txon = 1;
txoff = 0;
byte clock;
if (uSec > 32 && uSec < 1000) {
clock = (uSec / 4) - 1;
} else {
//default 140 uSec
clock = 34;
pinMode(tx_pin,OUTPUT);
cli();//stop interrupts
//set timer2 interrupt at clock uSec (default 140)
TCCR2A = 0;// set entire TCCR2A register to 0
TCCR2B = 0;// same for TCCR2B
TCNT2 = 0;//initialize counter value to 0
// set compare match register for clock uSec
OCR2A = clock;// = 16MHz Prescale to 4 uSec * (counter+1)
// turn on CTC mode
TCCR2A |= (1 << WGM21);
// Set CS11 bit for 64 prescaler
TCCR2B |= (1 << CS22);
// disable timer compare interrupt
sei();//enable interrupts
void lwtx_setTickCounts( byte lowCount, byte highCount, byte trailCount, byte gapCount) {
tx_low_count = lowCount;
tx_high_count = highCount;
tx_trail_count = trailCount;
tx_gap_count = gapCount;
void lwtx_setGapMultiplier(byte gapMultiplier) {
tx_gap_multiplier = gapMultiplier;
// LxTx.h
//Sets up basic parameters must be called at least once
extern void lwtx_setup(int pin, byte repeats, byte invert, int uSec);
//Allows changing basic tick counts from their defaults
extern void lwtx_setTickCounts( byte lowCount, byte highCount, byte trailCount, byte gapCount);
//Allws multiplying the gap period for creating very large gaps
extern void lwtx_setGapMultiplier(byte gapMultiplier);
// determines whether incoming data or should be translated from nibble data
extern void lwtx_settranslate(boolean txtranslate);
//Checks whether tx is free to accept a new message
extern boolean lwtx_free();
//Basic send of new 10 char message, not normally needed if setaddr and cmd are used.
extern void lwtx_send(byte* msg);
//Sets up 5 char address which will be used to form messages for lwtx_cmd
extern void lwtx_setaddr(byte* addr);
//Send Command
extern void lwtx_cmd(byte command, byte parameter, byte room, byte device);
Thanks if you can!
