identifier "Serial" is undefined
Hello,
I have a project that is trying to record audio than upload it. To record I have the VS1053 Codec + MicroSD Breakout:
To upload I will be using a particle E-Series:
https://docs.particle.io/datasheets/cellular/e-series-datasheet/
The issue I am running into is the error “identifier “Serial” is undefined”.
I am using the following libraries:
To test things out I used the attached code to ogg_record, this is example code found on github here:
Here’s the code being used:
  This is an example for the Adafruit VS1053 Codec Breakout
  Designed specifically to work with the Adafruit VS1053 Codec Breakout
  ----> https://www.adafruit.com/products/1381
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
// This is a very beta demo of Ogg Vorbis recording. It works...
// Connect a button to digital 7 on the Arduino and use that to
// start and stop recording.
// A mic or line-in connection is required. See page 13 of the
// datasheet for wiring
// Don't forget to copy the v44k1q05.img patch to your micro SD
// card before running this example!
// include SPI, MP3 and SD libraries
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
// define the pins used
#define RESET 9      // VS1053 reset pin (output)
#define CS 10        // VS1053 chip select pin (output)
#define DCS 8        // VS1053 Data/command select pin (output)
#define CARDCS A0     // Card chip select pin
#define DREQ A1       // VS1053 Data request, ideally an Interrupt pin
#define REC_BUTTON 7
Adafruit_VS1053_FilePlayer musicPlayer = Adafruit_VS1053_FilePlayer(RESET, CS, DCS, DREQ, CARDCS);
File recording;  // the file we will save our recording to
#define RECBUFFSIZE 128  // 64 or 128 bytes.
uint8_t recording_buffer[RECBUFFSIZE];
  Serial.println("Adafruit VS1053 Ogg Recording Test");
  // initialise the music player
  if (!musicPlayer.begin()) {
    Serial.println("VS1053 not found");
    while (1);  // don't do anything more
  musicPlayer.sineTest(0x44, 500);    // Make a tone to indicate VS1053 is working
  if (!SD.begin(CARDCS)) {
    Serial.println("SD failed, or not present");
  Serial.println("SD OK!");
  // Set volume for left, right channels. lower numbers == louder volume!
  musicPlayer.setVolume(10,10);
  // when the button is pressed, record!
  pinMode(REC_BUTTON, INPUT);
  digitalWrite(REC_BUTTON, HIGH);
  // load plugin from SD card! We'll use mono 44.1KHz, high quality
  if (! musicPlayer.prepareRecordOgg("v44k1q05.img")) {
     Serial.println("Couldn't load plugin!");
     while (1);
uint8_t isRecording = false;
  if (!isRecording && !digitalRead(REC_BUTTON)) {
    Serial.println("Begin recording");
    isRecording = true;
    // Check if the file exists already
    char filename[15];
    strcpy(filename, "RECORD00.OGG");
    for (uint8_t i = 0; i < 100; i++) {
      filename[6] = '0' + i/10;
      filename[7] = '0' + i%10;
      // create if does not exist, do not open existing, write, sync after write
      if (! SD.exists(filename)) {
        break;
    Serial.print("Recording to "); Serial.println(filename);
    recording = SD.open(filename, FILE_WRITE);
    if (! recording) {
       Serial.println("Couldn't open file to record!");
       while (1);
    musicPlayer.startRecordOgg(true); // use microphone (for linein, pass in 'false')
  if (isRecording)
    saveRecordedData(isRecording);
  if (isRecording && !digitalRead(REC_BUTTON)) {
    Serial.println("End recording");
    musicPlayer.stopRecordOgg();
    // flush all the data!
    // close it up
    recording.close();
    delay(1000);
uint16_t saveRecordedData(boolean isrecord) {
  uint16_t written = 0;
    // read how many words are waiting for us
  uint16_t wordswaiting = musicPlayer.recordedWordsWaiting();
  // try to process 256 words (512 bytes) at a time, for best speed
  while (wordswaiting > 256) {
    //Serial.print("Waiting: "); Serial.println(wordswaiting);
    // for example 128 bytes x 4 loops = 512 bytes
    for (int x=0; x < 512/RECBUFFSIZE; x++) {
      // fill the buffer!
      for (uint16_t addr=0; addr < RECBUFFSIZE; addr+=2) {
        uint16_t t = musicPlayer.recordedReadWord();
        //Serial.println(t, HEX);
        recording_buffer[addr] = t >> 8;
        recording_buffer[addr+1] = t;
      if (! recording.write(recording_buffer, RECBUFFSIZE)) {
            Serial.print("Couldn't write ");
            Serial.println(RECBUFFSIZE);
            while (1);
    // flush 512 bytes at a time
    recording.flush();
    written += 256;
    wordswaiting -= 256;
  if (!isrecord) {
    Serial.print(wordswaiting); Serial.println(" remaining");
    // wrapping up the recording!
    uint16_t addr = 0;
    for (int x=0; x < wordswaiting-1; x++) {
      // fill the buffer!
      if (addr > RECBUFFSIZE) {
                Serial.println("Couldn't write!");
                while (1);
          recording.flush();
          addr = 0;
    if (addr != 0) {
      if (!recording.write(recording_buffer, addr)) {
        Serial.println("Couldn't write!"); while (1);
      written += addr;
    musicPlayer.sciRead(VS1053_SCI_AICTRL3);
    if (! (musicPlayer.sciRead(VS1053_SCI_AICTRL3) & _BV(2))) {
       recording.write(musicPlayer.recordedReadWord() & 0xFF);
       written++;
    recording.flush();
  return written;
The error occurs in lines 47, 82, 107, 137, and 150
Serial.println(“Begin recording”);
Serial.println(“End recording”);
Serial.print("Couldn’t write ");
I’m currently using Visual Studio Code IDE, however I’m also willing to use the Particle Web IDE.
I was wondering the best way to import the Adafruit VS1053 library or if it’s possible to do it from the Particle Web IDE
How does one remedy this issue?
Pardon my being new to this and likely missing something.
I guess your main file is not an .ino file. In that case you'd just need to add #include <Particle.h> at the top of that file and then you should be good.
The Web IDE can import the Adafruit_VS1053 library (no need to import SdFat as Adafruit_VS1053 has the dependency defined already).
With VS Code you can use Ctrl+Shift+P Particle: Install Library to download the libraries (including dependencies).
BTW, I have not tested any of the legacy samples with Particle.
I only created and tested the Particle dedicated sample to ensure funcion of the library itself.
To use any of the other samples, you may need to tweak some things to account for the Particle specifics
e.g. this code would break the cloud connection and prevent you from OTA flashing new firmware
     while (1);
This should be changed to
     while (1) Particle.process();
Thank you for the response.
I managed to get the project working by using the Particle Web IDE and including two libraries:
I used the record_ogg example from the Adafruit_VS1053_Library and switch the #include <SD.h> with #include <SdFat.h> as well as added the line SdFat SD;
I’ve been successfully able to record an audio file. However, the process only works on the first attempt while the later attempts will fail at writing anything to the audio file.
This is the current code I have:
#include <SdFat.h>
#include <SPI.h>
#include <SdFat.h>
SdFat SD;
#define RESET D3      // VS1053 reset pin (output)
#define CS D5        // VS1053 chip select pin (output)
#define DCS D2        // VS1053 Data/command select pin (output)
#define CARDCS A2     // Card chip select pin
#define DREQ D4       // VS1053 Data request, ideally an Interrupt pin
int period = 5000;
unsigned long t_now = 0;
     while (1);
  delay(2000);
  if (millis() - t_now >= period && !isRecording) {
    t_now = millis();
    isRecording = true;
    char filename[15];
        break;
    if (! recording) {
       while (1);
  if (isRecording)
  if (isRecording && millis() - t_now >= period) {
      t_now = millis();
    // close it up
    recording.close();
    delay(30000);
      // fill the buffer!
            while (1);
    recording.flush();
    written += 256;
  if (!isrecord) {
    uint16_t addr = 0;
      // fill the buffer!
                while (1);
          recording.flush();
          addr = 0;
    if (addr != 0) {
      written += addr;
       written++;
    recording.flush();
  return written;
The code is recording a 5 second audio clip every 30 seconds.
I’m skeptical on whether the wiring of the E-series with the Adafruit VS1053 is incorrect.
This is my current wiring of the two devices:
A2 -> SDCS
A3 -> SCK
A4 -> MISO
A5 -> MOSI
GND -> GND
3v3 -> VCC
D5 -> SDCS
D2 -> XDCS
D3 -> RST
D4-> DREQ
I’m unsure if wiring is correct and was wondering if there’s a way to figure out how to convert the pin layout on an arduino to the Particle E-Series. The tutorial i’m referencing for recording in .ogg files is:
Thank you for the help.
You have two assignments for SDCS (A2 & D5) which one have you actually got wired?
Apart from MOSI (A5), MISO (A4), SCK (A3) and obviously the power pins all other pins can be selected freely as long your code matches the physical wiring.
But even the SPI pins (A3..A5) have their alternatives when you explicitly use SPI1 (on E-Series D4..D2) or SPI2 (C3..C1) in the library constructors.
Have you looked at the serial debug info your code is putting out on USB serial?
You got the device at hand, so you should be able to do the basic debugging.
BTW, I still see the code I pointed out as problematic unchanged.
There is also no reason to have the library include statements twice in your code.
Nor do you need #include <SPI.h> at all.
And this ...
... can better be written as ...
Adafruit_VS1053_FilePlayer musicPlayer(RESET, CS, DCS, DREQ, CARDCS);
