Hi, I've heard rumors that the M-series may count as both, which doubles the device count on blocks.
What does the official version say?
It counts as one device as it has one Device ID.
There isn't much of a differentiation between cellular and Wi-Fi devices for billing purposes. Data operations accrue at the same rate regardless of which is used.
Cellular data usage only applies when using the cellular connection, as it's measured by the carrier.
