It Appears there are two pins. Is there any new code required to output the higher resolution, or just the old code, pointing at either of the two pins?
thanks zach, I understand it is a really busy week.
When you are using a DAC pin, you can simply write a value from 0 - 4095 to it.
eg. analogWrite(DAC1, 2048);
analogWrite
will check if it is a DAC pin and do a HAL_DAC_Write
instead of a normal HAL_PWM_Write
Long story short, all you need to do with a DAC pin is to use it normally with a 0-4095 value.
^^ Exactly what that man said!
