Was doing some initial experimenting with the DAC analog output on my Photon and ran into a weird situation. According to the docs and common sense the larger analogWrite() values are supposed to correspond to higher pin voltages. What I’m seeing is that when I analogWrite(DAC, 0)
I get close to 3.3v but when I analogWrite(DAC, 4095)
I get close to 0.0v. The behavior seems to be linear in-between too.
Of course I’m second-guessing what I might have damaged now, as I may have briefly touched Vin (~5v) to the DAC pin, but having a functional but inverse behavior seems like a rather unusual failure mode. Anyone know what’s going on?
